586,390 active members*
2,740 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Oct 2006
    5
    z bavelloni egar 320
    does anyone have a source for the micro switch used in the probe assembly
    thanks Jim
    Nov 2006
    4
    eucher or eucker
    ng1fo-510
    011985 made in germany
    look on the net
    Nov 2006
    4
    euchner google it
    Apr 2007
    9
    Little topic change =)~
    If anyone else is using the same machine I'd love to pick at your brain about it. Thanks in advance
    Oct 2006
    5
    z bavelloni egar 320 brain pick
    I`am not the operator, but do the repair and maintenace on it.
    be glade to help any way possible
    tsjim
    Apr 2007
    9
    Thank you !
    I have one question for you because I can't find anything like this in the maintenance manual. Next to the vaccume pump there is an air tank that collects water and next to that theres another tank with the air filter. I dont know or even understand why but sometimes, it seems that the vaccume pump is letter oil into the air filter tank. It does not happen when the water/air tank is full or anything but randomly. Do you by any chance know why this is happening and if so what I can do to stop it?
    Thanks again !
    Oct 2006
    5
    zbav oil
    having rebuilt the vacuum pump 2 times, there is no reason oil should get that far back into the system, water should be drained every time the pump is turned off and water level in the pump should be checked daily,and drained as well, the pump can overfill its self with water/oil
    from normal use.
    we have an ocienian that is used most of the time and the vacuum pump
    has a separate tank (30gal) used to keep water out the system.
    much better design than the z bav, how old is your machine?
    thanks tsjim
    Apr 2007
    9
    My machine is about a year and a half old. Not sure about model wise and their upgrade rate but thats when we got ours.
    There any chance you could snap a few pictures of that setup you have?
    To be perfectly honest with you. I went to college for web design and interactive media design. I took this job because I have an aptitude for learning software quickly and the machine part just came with reading the instructions and a few lessons. So basically, when it comes to the engineering portion of the machine I'm limited. I'd be greatful if you had any more tips on how I can better the efficency of my machine.
    Thanks man =)
    I appreciate it
    Feb 2005
    51
    I have worked extensively with bavellonis and Northwoods alike and hold very high stature with both companies...the Bavelloni possess a dry pump which has a water seperator and a dry pump no water allowed!!!! If you back flush your system by mistake....linking the float and vac cup prots together by accident....oil can get blow back into the filter....also if you suck some water up into thzt badboy, stuff gets funk and the whole system acts weird...depressurizes and oil leaks back into the water seperator....if this happesn you need to change the vac oil...its is contaminated and your measureble vacuum -pressures will indicate this...
    Jimbo
    Jan 2008
    5
    Hi everybody!
    do you still have problems with the pump? maybe I can help. I was a Bavelloni CNC technicain.
    Fabio
    Oct 2006
    5
    edgar 320 zbavalloni
    pump if ok,the machine is for sale.(cheap 40k)
    we replaced it with an ocieania
    thanks Jim
    May 2009
    Milling(finger) bits for an egar 320
    I have had an Z Baveloni egar 320 machine for about 4 years now and i have figure most thing out about this machine. but recently i have been having a problem with finding a good milling bit. i have tried just about everything and yet to find one fast or stron enough. any one have any suggestions as to what is the best milling tool for this machine. is there one that would be better to use on dark stones compared to the lighter softer ones? anything you could give me would be a great help.
    Jan 2008
    5
    there are planty of producers of good millings for exapme: Nicolai, Adi, Vincent, Diamut... the important thing is the diameter that should be max 20 mm. the working parameters are: 3000/5000 r.p.m. (spindle rotation), 0.1/0.4 mt/min (speed in meter per minute). another important thing is to have internal water with pressure 4/5 bar, 20/25 l/min (liter per minute) and recicled external water should have a precise direction on the tool. these parameters are for granite thickness 30 mm. all my customers are working with these parameters and are doing OK.
    Ciao,
    Fabio
    Jun 2009
    hi everyone ,
    myname's Bao
    my z-bavelloni have error " head out of position"
    when it move , i chose parameters
    please help me repair it
    Jun 2009
    Quote Originally Posted by capo nord View Post
    Hi everybody!
    Fabio
    i have a glass z-bavelloni 372
    when machine move , i clicked f7( paramaters) and chose visual marco utility .
    then it don't move and have one error " head out of position"
    i hope you can help me , soon by soon
    i'll wait your mail
    thanks a lot
    Jun 2009
    Hi everybody!
    Fabio
    hi!!1
    i forget my mail
    my mail is " [email protected]"
    thanks agian
    Jan 2008
    5
    unfortunately I can not help as I am specialized only in the numerical control machines and not on cutting tables... sorry.
    Ciao,
    Fabio
    Jan 2010
    Bridge boot
    Does anyone know where I can buy a left side bridge boot for an egar 320 at a reasonable price?
    Jan 2008
    5
    sorry but I did not understand exactly what you're looking for
    Guys sorry for going off topic. Metro, you want to get my XXX red or my Yellow z5 >> http://www.nicolaidiamant.com/swf_ca...cnc/index.html Call with any questions.
    Direct - 847-388-0165 - www.helixtools.net - http://helixtools.tumblr.com/
    Email - [email protected] - http://bit.ly/re9sMI
Page 1 of 2 12
