586,042 active members*
3,730 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > KFLOP error SetToolLength(TWORD,NewToolLength);
Results 1 to 8 of 8
    Feb 2015
    19
    Hi!
    I have problem:
    If using SetToolLength(TWORD,NewToolLength) in version 4.32.
    Table is populated incorrectly.Instead of changing the current length of the tool, create a new string with the same number. Sometimes the data are not replenished at all.
    What could be the problem?
    Thanks!
    May 2006
    4045
    Re: KFLOP error SetToolLength(TWORD,NewToolLength);
    Hi Smouk,
    Please use our latest Test Version it has many new features and fixes regarding the Tool Table.
    http://dynomotion.com/Software/KMotion433k.exe
    Regards
    TK
    Feb 2015
    19
    Thank you! Version 4.33 has solved problems with the table.
    But with the change of the tool having difficulty.
    1. If choose the tool manually, the length compensation works.
    2. If change the tool via the command M6 - the length of the tool is not compensated for, in what could be the problem?
    PS Why two new buttons next to feedhold?
    May 2006
    4045
    Hi Smouk,
    To apply the Tool Length Compensation in GCode a G43 Hxx must be included with the H word to specify which tool should be used for Length Compensation. Are you including this?
    The buttons next to FeedHold allow the operator to move forward or backward slowly while in Feedhold. See:
    https://youtu.be/uPQfGeydsDM
    Regards
    TK
    Feb 2015
    19
    Tom, thank you! In version 4.33k tool table and LenghtTool works fine.
    I asked here about these buttons next to feedhold:
    Why should they? Feedhold the new version works strange. It is not always possible to turn off. Have to press the Pause button. Press "FeedHold" work not always :(
    Thank you for your support!
    Attached Thumbnails Attached Thumbnails IMG_20150425_142903.jpg   IMG_20150425_142926.jpg
    May 2006
    4045
    Were you able to watch the video to see how they work?
    Normally releasing FeedHold seems to work properly, unless you are in Soft Limits or a Limit Switch. Could that be the case?
    Regards
    TK
    Feb 2015
    19
    Tom, I'm sorry - I did it until the end of the video, because I thought that you did not understand my question. Now everything is clear.
    About feedhold: works hardware limit(see in console), but does not always move on return. Previously, it was necessary to simply click on "feedhold", now it does not always work and sometimes helps button "pause".
    May 2006
    4045
    Hi Smouk,
    Yes I believe we have found some numerical roundoff issues causing this. We hope to have this fixed in the next Test Version 4.33l that should be coming out soon.
    Regards
    TK
  1. Bought a KFLOP: Need help
    By gnomore in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-19-2015, 11:41 PM
  2. Replies: 8
    Last Post: 02-06-2015, 03:56 PM
  3. KFlop PWMs
    By SCzEngrgGroup in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-08-2014, 03:24 PM
  4. kflop by itself?
    By markymark1 in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-20-2014, 07:19 PM
  5. KFlop 4.3
    By John Coloccia in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-03-2013, 07:57 PM
