Hey guys,
I'm running a job at the moment and have just set up ~24 tools in our EC400. Now the tools that require diameter probing do so nicely, and output the measured diameter into the tool diameter column of the offsets page. However, this alters the diameter in the control, and doesn't change the wear column.
Currently, I'm using Mastercam X8 and having it use wear compensation (rather than control) because it has less of a chance for catastrophic failure (a few thou here or there rather than half a tool). Is is possible to either:
A: Change how the probing system outputs its diameter settings, along the lines of "Actual Diameter"-"Diameter" and input
that into the wear column? or:
B: Should I just be using control compensation and stop worrying about it.
Thanks!
EDIT1:
After much googling, I found this
Thread
Which provides the following:
I can do it here, I guess. It's not like a secret Fanuc parameter or something.
In the case of which I speak, the edit is in program O09852. I would suggest uploading it somewhere for safe keeping, just in case it gets hosed up.
Anyway, change setting 23 to OFF, so you can edit 9000 series programs.
Open O09852.
Find the line N31.
The next line should read: #[ 2400 + #7 ]= #8 / #156
Change it to: #[ 2400 + #7 ]= #8 / #156 - #19 (add the -#19 to the end)
When finished, select some other program than a 9000 series.
Reset setting 23 to ON.
Try it, but check what it enters into your offset page before you run that tool.
Setting 40 on our VF3 is set to "DIAMETER". If the tool is supposed to be .500 and is .490, our offset page will show -.010.
Again, verify what's entered into your offset table vs. what setting 40 is set to before running.
I'm going to give that a shot, I guess.
EDIT2: So I gave that a shot, and it outputs the amount of wear correctly, however does so into the tool diameter column, not the wear column.
Any ideas?
