587,013 active members*
3,803 visitors online*
Page 5 of 5 345
Results 81 to 85 of 85
  1. #81
    Sep 2005
    106
    Re: 2010 screenset
    Thanks Gerry,
    i will make the changes tonight after work.
  2. #82
    Nov 2013
    152
    Re: 2010 screenset
    Quote Originally Posted by rbraeking View Post
    I'm sure it is the same card. There are 3 variations depending upon the number of axes. I modified the macros to work with my card. I replaced the GetVar(2002) with GetDro(802). Then I added a CallSet between each probing sequence to increase accuracy. I have the simple zero working fine. I'm looking for a location for my fixed block then will modify that macro as well.
    Bob
    Bob,
    Did you get the 2010 probing working with the XHC Mach3 USB motion card?
    They released a v2.39.9 on 2017.9.19. The release notes state: "Set the probe user dro 2000,2001,2002 to replace the variable 2000,2001,2002.
    so user could getuserdro(2000) to replace the GetVar(2000) when probing."
    I'm trying to get this working now on 3.043.062..
  3. #83
    Oct 2012
    179
    Re: 2010 screenset
    [QUOTE=slodat;2171688]Bob,
    I have given up on the XHC card and switched to a C62 card behind a smooth stepper. The XHC crashed too many times.
    Currently the problem I am having is that the fonts on the Screenset are too big for the windows. I tried everything I know to do with screensize and resolution but still get oversized font. What am I missing?
    Bob
  4. #84
    Re: 2010 screenset
    In the 2010 Screenset? Can you show me what you are talking about? The fonts in the screen are a fixed size, and can't be changed.
    I'm guessing the issue you are talking about is due to a Windows Font Size Issue, and it's not the actual screen that has the issue?
    Or do you mean the fonts in the DRO's?
  5. #85
    Oct 2012
    179
    Re: 2010 screenset
    Problem Solved. Had large fonts chosen in Control Panel/All Control Panel Items/Display. Changed to 100% font and the problem resolved itself. New problem has to do with my need to see my Optometrist........or get a 72 inch screen
Page 5 of 5 345
  1. Screenset 2010
    By cubalu in forum Mach Wizards, Macros, & Addons
    Last Post: 06-12-2014, 11:40 AM
  2. Besoin d'aide Screenset 2010
    By cubalu in forum French
    Last Post: 06-05-2014, 11:44 AM
  3. How do I wire a touch plate for the 2010 Screenset?
    By offthewall in forum Screen Layouts, Post Processors & Misc
    Last Post: 02-03-2014, 05:38 AM
  4. Probing inside corners with the 2010 Screenset
    By Megaplow in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-23-2014, 08:18 PM
  5. 2010 Screenset error confusing me....
    By racedirector in forum Mach Software (ArtSoft software)
    Last Post: 05-25-2012, 04:47 PM
