586,047 active members*
3,683 visitors online*
    Feb 2005
    117
    Mach3 feedrate CHANGES
    I am having a problem with federate both in X and Z axis changing by Itself.
    I have no F commands in the program. Only G00 and G01. No corresponding
    feed commands.
    Several times the machine has taken of with federate increasing.
    I try to adjust using the feed icon with no response.
    I have to hit the escape key of stop icon hopefully before I break an insert.
    This is a conversion on a small Monarch turret chucker.
    I am using gecko drives.
    Last where do you change the default feed rate in the program?
    Any help would be appreciated.
    Thank you.
    15362
    Re: Mach3 feedrate CHANGES
    johnd
    There is no default Feed Rate in your Program, it is what you set it to, with the F command
    There is no magic here, when you have a G00 it will move at what your max is set for, in your machine control
    After using a G00, if you have a G1 move, you need a ( F--. ) Feed at the end of that line, if not the control will try to move at the rapid that is set for the G00 move
    So everytime it changes in the program from a rapid ( G00 ) to a feed ( G1 G2 G3 Etc ) you need to tell the control how fast you want those move's to be with an F20. at the end of the line
    G00X20Y4.
    G1 X25 Y10F20.
    Mactec54
  1. Mach3 running only 75% of feedrate
    By DirtBound in forum Machines running Mach Software
    Last Post: 06-08-2013, 10:38 AM
  2. Feedrate override vs programming a faster feedrate?
    By Zeppelin1007 in forum Mach Software (ArtSoft software)
    Last Post: 01-11-2013, 10:38 PM
  3. c axis feedrate
    By cincom in forum CNC Swiss Screw Machines
    Last Post: 09-10-2010, 02:41 AM
  4. Mach3 feedrate override
    By dynamotive in forum Mach Software (ArtSoft software)
    Last Post: 09-24-2009, 11:04 PM
  5. G02, G03 Feedrate !!!!!
    By usb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-16-2008, 01:19 AM
