586,052 active members*
3,935 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > RF-45 Clone Mill > Looking to pull the CNC conversion trigger
Page 3 of 7 12345
Results 41 to 60 of 125
  1. #41
    Jun 2008
    467
    Re: Looking to pull the CNC conversion trigger
    91TSiGuy,
    Thanks for the super fast reply, I could use one of our donut hole cutters but it might not be good for food service afterwards.
    Live from downtown Burbank, home of the endless Cup-O-Joe.
    JoeyB
    A doughnut a day keeps the doctor away.
  2. #42
    Apr 2010
    104
    Just a heads up, the shim material is about as thin as I'd go for these import disc cutters. Their side wall clearance is right at the point where the shim can become pulled between the cutter and hole. Using a sacrificial piece of sheet metal under the shim stock while cutting could help I believe ( perhaps above it--i can't recall what i read)
    Sent from my VS985 4G using Tapatalk
  3. #43
    Jun 2004
    6618
    Te sacrificial part is where I see a real use for MDF on one off parts.
    Lee
  4. #44
    Sep 2006
    509
    Thanks for the answer, I need to get in and shim my Z now, and seeing a non spring loaded double ballnut gives me confidence to try my own perhaps (I think X is the easy 1st try for me).
    Mike
  5. #45
    Apr 2010
    104
    $25 in materials, an hour of time, and I have some make-shift chip containment.
  6. #46
    Apr 2010
    104
    Limit/homing switches wired up. Each axis got it's own input on the breakout board.
    Rear Y switch, ends up covered by the bellows.
  7. #47
    Apr 2010
    104
    First useable part made with the conversion-- gas struts upper mount.
  8. #48
    Apr 2010
    104
    The upper mount is a bit too wide to swing the head from 90* to upright after bolting it on so I had to drop the middle bolt and only use the side ones for attachment. I thought cutting off the corners of the bar would work but it wasn't enough. Oh well, the gas struts are on.
  9. #49
    Apr 2010
    104
    A quick engraving job tonight to see how things would come out. Mach4 seemed to freeze with the one gcode can bam put out asking for a tool change pause. Not sure why-- I deleted the tool number and description and then redid the code. Worked as it should that time.
  10. #50
    Apr 2010
    104
    I'm trying to get the post processor to work with Fusion 360 but keep getting a failed output code. Here's what I'm seeing for a simple flycutting opperation, 2 pass, .020" deep. I have Mach4, but that's not an option of a post processor output, only Mach3. I'm not quite sure what else I'm missing here -
    Information: Configuration: Generic Mach3Mill
    Information: Vendor: Artsoft
    Information: Posting intermediate data to 'C:\Users\Owner\AppData\Local\Fusion 360 CAM\nc\1001.tap'
    Information: Total number of warnings: 1
    Error: Failed to post process. See below for details.
    Code page changed to '1252 (ANSI - Latin I)'
    Start time: Friday, July 22, 2016 1:31:19 AM
    Code page changed to '20127 (US-ASCII)'
    Post processor engine: 4.2.1 40927
    Configuration path: C:\Users\Owner\AppData\Local\Autodesk\webdeploy\pr oduction\f61ab1dfd94b3aa875226de3a402c49fbd3874b6\ Applications\CAM360\Data\Posts\mach3mill.cps
    Include paths: C:\Users\Owner\AppData\Local\Autodesk\webdeploy\pr oduction\f61ab1dfd94b3aa875226de3a402c49fbd3874b6\ Applications\CAM360\Data\Posts
    Configuration modification date: Thursday, June 02, 2016 7:33:38 PM
    Output path: C:\Users\Owner\AppData\Local\Fusion 360 CAM\nc\1001.tap
    Checksum of intermediate NC data: f081d3a33c3f1b9b27ebee2b5e377980
    Checksum of configuration: 7d0b9ca9d2b54f29ab3f878eb9efb238
    Vendor url: Newfangled Solutions » CNC Software Home of Mach3
    Legal: Copyright (C) 2012-2016 by Autodesk, Inc.
    Post processor signature could not be verified (error 0xfffffffc).
    Generated by: Fusion 360 CAM 2.0.2204
    Warning: Work offset has not been specified. Using G54 as WCS.
    Error: Invalid coolant mode
    Error: Failed to invoke function 'onSection'.
    Error: Failed to invoke 'onSection' in the post configuration.
    Error: Failed to execute configuration.
    Stop time: Friday, July 22, 2016 1:31:20 AM
    Post processing failed.
  11. #51
    Jul 2004
    108
    Thank you for a well-documented log, bud, will come in handy when I tackle the mechanical side on mine.
    Top effort, luv it.
    Cheers,
    Beano
  12. #52
    Apr 2010
    104
    I think I found the error with the above code. I disabled coolant in the setup options for each step and it looks to be good to go.
  13. #53
    Jul 2016
    Tagged
    sent from the Honey Badger Galaxy
  14. #54
    Apr 2010
    104
    Added a new accessory to the arsenal and gave it a try today.
  15. #55
    Apr 2010
    104
    Made a little progress with the machine, but not as fast as I wish I could. I began mounting and running the oiling pump and lines and secured the limit switch lines, so basically there was a lot of drilling and tapping of cast iron.
    I also hooked up my compressed air to some eBay nozzles and an old regulator to use for cooling and chip clearing. This required me to cut and reweld the mounting flange for the mills original flood coolant bracket when I wanted to move it to the left side of the machine.
  16. #56
    Apr 2010
    104
    Swapped out the temporary chip clearing air supply line with a slimmer coiled line.
    I also made some progress with the oil supply lines for the ways and ballscrews. I'm not in love with how I think the ballscrew oil lines will work but I'll wait and see if they're an issue. The z screw oil line I still need to finish.
    Last week I also bent up a table extension cover ala tormach style so I'm excited to mount that permanent.
  17. #57
    Apr 2010
    104
    Table extension cover installed
  18. #58
    Dec 2013
    290
    Nice work on the guard
    Work: Hurco VMX42/VMX50 - Shopsabre 4896 - Bobcad V4 4axis pro
    Home: RF45 with Ajax CNC Controller - Bobcad V27 3 axis pro
  19. #59
    Apr 2010
    104
    Thanks.
    Added another cover for the y axis coupler.
  20. #60
    Apr 2010
    104
    Because why not be a cnc newbie and jump into 3d machining, ha! My cam definitely needs some work. The cross hatch look was intentional but the 3 notches on the side weren't.
Page 3 of 7 12345
  1. Replies: 17
    Last Post: 05-05-2017, 01:22 AM
  2. Before I pull the trigger on a build .
    By Kru82 in forum DIY CNC Router Table Machines
    Last Post: 03-07-2015, 10:02 PM
  3. About to pull the trigger but have questions.
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-20-2012, 06:06 PM
  4. About to pull the trigger on a Grizzly G0602
    By akschu in forum Uncategorised MetalWorking Machines
    Last Post: 08-28-2008, 09:36 PM
  5. RFQ trigger and block....
    By impact in forum Employment Opportunity
    Last Post: 11-04-2004, 07:51 AM
