Hello , is it possible to setup a wireless USB (transmitter and receiver type configuration) to send programs from PC to the HAAS machine controller ?
Yes, you can use ShopLink LOW COST Wireless for a bulletproof solution.
Highland DNC, LLC.
There is a serious weirdness in the Haas USB reading. After getting pissed and buying 12 different USB Thumb drives from Fry's (every model they had) I found only two that will work. I tried formatting the ones that wouldn't too, but the best I could get was for the Haas to think for 15 seconds THEN load the drive.
SanDisk Cruzer Glide 16GB is the best of the lot. I have 2 and they both work. I have several other SanDisk drives with "the same format" that don't work. Weird.
Did you format fat32 or NTFS or..? I've stuck several generic ones in the Haas's and all have worked.
What year is your Haas? I formatted FAT32, exFAT, and NTFS.
I was pretty frustrated that I had 3 USB drives and couldn't transfer a single file to my machine which was set up and wasting time unable to run.
Ended up going to Fry's and buying every single stick model they had because I was losing money
I think 2011 and 2012.
Mines a 2014. You would think it would get better as the years go by
