586,463 active members*
3,316 visitors online*
Results 1 to 9 of 9
    Apr 2015
    6
    Extended edit parameter
    Hi, Does anyone know what parameter number and bit turns on extended edit on a Fanuc18i-TB control.
    Thanks in advance.
    Aug 2011
    2517
    Re: Extended edit parameter
    the admin does not like people publicly talking about secret options.
    check your PMs
    Apr 2009
    1379
    Note that you may not be able to even view the options(parameters 9000 up).
    Aug 2011
    2517
    options start at 9920 on 16/18/21 and i-series ;-)
    normally you can see, especially on the i-series. I can see mine just fine and I have a 21i. they also punch out without any tricks :-)
    anyway, it's a pretty useless option if you ask me. punch out program and edit with notepad is much faster and easier when making complex copy/paste edits. I never use extended edit. Primarily because Mori MAPPS allows copy/paste directly at the control :-D
    Apr 2009
    1379
    Some iA and many iB controls have the parameters from 8900 up passwords protected; these are stored in flash, not sram and are not viewable. I am working on this.
    Oct 2013
    7
    Quote Originally Posted by fordav11 View Post
    check your PMs
    Hey Ford....... I got the same question
    Sending PM
    Oct 2013
    7
    check your PMs
    Sending PM
    Oct 2013
    7
    Well, I tried sending a PM...... Not sure if it is working for me. Maybe I don't have enough posts.
    Anyways, I'm looking for the same info if anyone can help me out.
    Jul 2020
    5
    hi everyone kindly tell me how to turn on this EXTENDED EDIT OPTION IN FANUC-OT CONTROL.
  1. Extended Edit Parameter?
    By Mill Head in forum Controller & Computer Solutions
    Last Post: 11-29-2019, 06:35 AM
  2. How edit and save a parameter change Mitsubishi control
    By Replication in forum Mori Seiki lathes
    Last Post: 11-05-2014, 05:48 PM
  3. Replies: 1
    Last Post: 11-17-2013, 06:21 AM
  4. edit key offset parameter
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-28-2009, 03:54 PM
  5. 11M extended edit features
    By chuy in forum Fanuc
    Last Post: 07-23-2007, 10:10 PM
