I am trying to transfer a part using the CAPS Conversational Programming Interface. The G Code looks perfect, the second spindle moved up to the part, a push check is executed, the second spindle chuck is clamped perfectly, but then after the M11 command, the spindle 1 jaws open but the program simply stops/hangs
A reset is needed to get out of the program.
In MDI mode, If I bring the second spindle into to part by hand and execute M210 Spindle 2 Clamp followed by M11 Command, no more programs can be entered after the M11 Command - error message "operation is in progress".
For some reason, the M11 command is not allowing other commands to be run after it.
Any suggestions?
