586,329 active members*
5,027 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Indexing and Rotary using BobCAD CAM V27 4 Axis Standard
Results 1 to 11 of 11
    Mar 2012
    1570
    This 20 min video walks through a sample part using indexing and rotary toolpaths.
    https://youtu.be/s-4kPGgHfpI
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jun 2010
    104
    Re: Indexing and Rotary using BobCAD CAM V27 4 Axis Standard
    Wow! Al is on fire!
    Thanks so much. Great stuff.
    Jun 2012
    21
    Hi Al,
    You seem very familiar with this. I suppose you should be
    I have a few question of capability. Sales guys don't really know. Could I chat with you for a few minutes?
    I'll PM you my contact info.
    Thanks!
    Denny
    Mar 2012
    1570
    Quote Originally Posted by denphillips2 View Post
    Hi Al,
    Thanks!
    Denny
    My pm doesnt work on cnc zone. Just call me on my cell.
    Al DePoalo
    Jun 2012
    21
    Ok, Al,
    Is that your cell listed in your signature?
    I am available about any time also. 720-209-0142
    Thanks!
    Jun 2012
    21
    Just called that number, and got a lady at BobCad. She will give you a message from me Friday, If you could call me sometime before that please. 720-209-0142
    Much appreciated,
    Denny
    Dec 2011
    295
    Hey Al! When you select axis of rotation point which isn't on the WCS/ mechanical axis, the toolpath envokes a Y move to stay surface normal. Is that available with Bob 4ax std?
    Mar 2012
    1570
    LeWhite,
    The toolpaths that I used in this part was done using the BobCAD CAM 4 axis standard. You do get a shift in Y for the new base point location ( axis or the rotary toolpath ). But I am not sure if that is really what you are asking. I think you are asking is if the 4 axis standard offer true 4 axis control of X Y Z A at the same time?
    Al DePoalo
    Dec 2008
    4548
    Quote Originally Posted by LeWhite View Post
    It's not really staying "SURFACE" normal... It's staying "AXIS" normal.. So if you have a 4 inch cylinder chucked up at center then set the 4th rotation axis point in BobCad to be below the center point, when the rotary starts to turn around, the tip of the tool will be moving back and forth in Y as the cylinder turns...Tracking that new axis point inside of the 4 inch cyl.
    Dec 2011
    295
    @burrMan. Yes Axis normal requires Y motion when axis of rotation is not center of rotation. When axis of rotation is coaxial to center of rotation there is no Y motion. This has little correlation with surface normal. Thanks, as I have lived my whole life to get to this point. And its all in Bob4axstd.
    I owe burrMan a few beercoin and Al tacos at Westec
    Mar 2012
    1570
    I ll take the tacos for sure!!!
    Al DePoalo
  1. V25 4th Axis Standard / Rotary
    By RAF. in forum BobCad-Cam
    Last Post: 10-20-2013, 04:00 AM
  2. Replies: 1
    Last Post: 08-24-2013, 11:51 PM
  3. FORTH AXIS STANDARD INDEXING
    Last Post: 07-30-2013, 06:04 PM
  4. BobCAD CAM V25 4 Axis Standard
    By aldepoalo in forum BobCad-Cam
    Last Post: 09-28-2012, 12:45 PM
  5. So I stumped BobCad. 4th axis indexing
    By nate in forum BobCad-Cam
    Last Post: 06-26-2012, 11:57 PM
