Briquetting machine, also called briquette press machine, briquette maker or ball press machine, is an ideal mechanical equipment designed for processing powdery materials, such as nonferrous metal powder and mineral powders, including iron powder, iron ore powder, coal powder, and so on. The finished briquettes come with high intensity, great convenience for transportation and various shapes. Custom-made shape is also available. The commonly used briquetting machines are charcoal briquette machine, small briquette machine, coal briquette machine, lime briquette machine (Lime Briquetting Machine,Quicklime Briquetting Machine,Lime Briquette Press Machine - Fote Machinery), urea briquetting machine, etc.
The difference of briquette machine operation condition and environment condition is very big, many in the form of parts failure, the causes of failure are different. Generally by the external morphological characteristics of the failure parts to classify, mainly has wear, deformation, fracture, corrosion depth four kinds of common typical failure forms. In production practice, the main failure forms is the wear failure on the parts work surface, and the most dangerous failure modes is instantly appear crack and breakage, collectively known as the fracture failure.
A component failure, should study mechanism of strong pressure ball machine (Strong Pressure Briquetting Machine/Strong Pressure Ball Machine-Fote Ball Press Machinery) wear and fracture, deformation, corrosion phenomenon or process characteristics, find the main reason for the failure, in order to provide reliable basis for making maintenance technology strategy, and carries on the control factors as to the cause of failure, in order to reduce the briquette machine failure rate, prolong its service life.
But fundamentally solve dry powder briquette machine parts failure is to do daily inspection to briquette machine parts, including parts geometry precision, surface quality, mechanical properties, hidden defects, etc, only in the daily use process to do good job of detection, to reduce parts failure probability, and thus reduce the damage and loss.
If you are interested in good briquette machine for sale, welcome to contact or visit Fote Machinery: [email protected].
