Does anyone know where i could get one of these manuals? Or does anybody here have one they could copy some info and diagrams form?
I have the 10M/11M/12M Maintenance manual, what do you need?
I have later ones in PDF from 15 up.
Al.
Albert E.
Any idea where i could buy it? I'd really like to have one.
Try Ebay
i've got a copy .. 704-996-5737 ... prog. and maint
Like a "copy" to sell?Originally Posted by EDM_Fixer
Send your email to my private messages
n174k
Does either manual say anything about the counter and data parameters? This is in the pc side. You can go there by pressing the nc/pc key located by the can key. I believe fanuc lost some info when they changed my master pcb. and now I have 15 tools where I had 20 before. If you could take a look at yours and tell me what numbers are in there for the counter and data it might get me back my tools, Thanks Jamie
Unfortunatly if the information you need is on the PMC side, this won't necessarily be in the Fanuc manuals, as the PMC is generally up to the OEM to write, so will be unique to a particular design of machine, the only way in that case is to get the information from someone with an identical machine.
Al.
Albert E.
