586,100 active members*
3,239 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Engraving some names on aluminum tags
Results 1 to 13 of 13
    Apr 2015
    10
    Hi Everybody,
    My name is Dan and I need some help!
    I have a lot of names to engrave in some aluminum tags.
    The project is made in Artcam and I am using ISO font. (line font)
    The thickness of a letter must be 0.8~1 mm
    The problem is that I tried to use DATRON end mills but got them broken or the edges remain ugly.
    Also tried to use DATRON 30 degree mills but after 3~4 tags, the mill needs resharpening.
    Can anyone give me an advise?
    Thanks!
    Aug 2005
    300
    Re: Engraving some names on aluminum tags
    What is your spindle speed? This is very important when using small cutters. Also what do you mean by thickness?
    Ernie
    Apr 2009
    5516
    You'll break or dull the tip trying to do that in one pass with a 30° tip... You can try a 90° which should also help with burrs. Chipload should be very small, ao unless you have a high speed spindle you'll have to take it slow...
    Oct 2006
    340
    For letters so small I use a non rotating springloaded diamond with medium spring pressure.
    Apr 2009
    5516
    Quote Originally Posted by br1 View Post
    But he's using a single line font and needs 1mm letter thickness so that's out of the equation.
    What you CAN do with a spring loaded holder is use a burnishing bit, they should have one with 1mm cut width. Used normally for marking in lacquered brass.
    Apr 2005
    861
    I suspect something in the set up is seriously wrong if you are wearing out a Datron cutter in aluminium after such little work. What is the total cut time for the 3 parts? Unless it is many many hours, I would almost wonder whether your spindle is running in reverse...
    LongRat
    www.fulloption.co.uk
    Apr 2004
    5737
    How fast is your spindle going? How many flutes on those endmills? Are you using flood coolant, mist, or cutting dry? What kind of aluminum is it?
    For jobs like this, you need high spindle speed, single or 2-flute cutters, lots of lubrication, and heat-treated aluminum, or the metal tends to stick to the cutter.
    Andrew Werby
    Website
    Apr 2015
    10
    Quote Originally Posted by ErnieD View Post
    Ernie
    My spindle speed is 24000 rpm.
    For thickness, lets take the letter I, I need to use a 0.8mm end mill to get the thickness 0.8mm.
    Apr 2015
    10
    Quote Originally Posted by awerby View Post
    Spindle speed is 24000 rpm
    1 flute on the end mill DATRON
    cutting dry, but was thinking to use some cooling fluid.
    I am not sure for the aluminum type, I got it from the client. (I saw one made someone else and it looked great)
    Jan 2007
    1795
    datrons has high rpm spindles.. up to 60K
    for aluminum you can go a lot higher rpm then 24K
    engraving bit and flat tip, at least 0.5 mm.. the 30 deg bit is ok..
    you might go with 2-3 passes, but for engraving don't need real depth..
    if your tool is dulled, then only reason I can imagine, the material deposited on the tip and it breaks.. due low rpm or too high feed..
    for aluminum you can use denatured spirit, or simply wd40..
    Apr 2009
    5516
    Remember you really got to take light passes with a sharp 30deg. cutter as the tip is really fragile. Also why I recommend at least 90deg. or more angle, as you won't need to cut as deep to affect a thicker line.
    If you use a straight endmill, I'd suggest going pretty light with the passes. I actually engraved a brass name plaque using an .020" endmill, to get into the serifs. I had to use .007" passes to keep the tool from snapping. I'd have used a v-bit, but the sample I was shown had vertical walls in the lettering.
    Apr 2015
    10
    Quote Originally Posted by louieatienza View Post
    OK noted.
    I was looking for a 90deg tool and found this.
    Please check attached.
    D1= 3 mm D2= 3 mm L1= 40 mm L2= 2.5 mm α= 60 °
    In your opinion, will this work?
    Apr 2009
    5516
    Quote Originally Posted by DDA1986 View Post
    OK noted.
    Looks like it will do.. I'd agree with the others and brush on a light coat of WD-40...
  1. Engraving Aluminum
    By charger19690 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-01-2012, 06:32 PM
  2. engraving names on a ring in the 4th axis
    By Michael82 in forum Mastercam
    Last Post: 01-12-2012, 03:06 PM
  3. engraving names necklaces
    By coykiesaol in forum Jewelry Design Software
    Last Post: 02-19-2011, 09:49 AM
  4. Black areas on anodized aluminum tags
    By firejoe911 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-17-2009, 06:10 PM
  5. rfq on .125 aluminum engraving
    By cncsdr in forum Employment Opportunity
    Last Post: 01-23-2007, 01:34 AM
