586,069 active members*
3,553 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > My DIY CNC router design.. any good?
    Apr 2015
    Question My DIY CNC router design.. any good?
    Hi all,
    i'm thinking about building a CNC router for a long time now.. I started working on a design i would like (and could afford)..
    It would be 16mm MDF construction, linear would be L profile with rollerskate bearings, NEMA 17, overall dimesions 600mmx1000mm..
    Does anybody see anything wrong with this design?? Anything that wouldnt work? I know some linear rails would be better, but i don't really need 0,01mm repeatability..
    Any comments would be appreciated..
    https://www.dropbox.com/sh/a652ubahx...jBAj0SkDa?dl=0
    Apr 2009
    5516
    Re: My DIY CNC router design.. any good?
    I'd probably double at least the gantry legs and bridge to add stiffness. I think also decreasing the distance between pinion and idlers will help mitigate belt stretch; a 180deg. wrap of the belt on the pinion would be ideal.
    Other advise would be to look into using round tube or drill rod for the rails. This way even if the angle of the bearings is not a perfect 90deg, they'll still ride well on a round rail. It may teeter-totter on the angle iron. Also dust or debris on the flat may cause a jam, where it would be pushed away with round rail...
    Apr 2004
    5737
    I think NEMA 17 motors are too small for a machine this size. Go with NEMA 23 instead. That Dremel tool won't last long in this application; the plastic housing distorts when it gets hot, and then it dies. Get a real router instead. And the MDF is okay for a table, but find a piece of aluminum to use as a gantry; MDF isn't rigid enough to do much for you there. I've seen that kind of belt drive used on 3D printers, but I don't think it's positive enough to keep your machine steady against cutting forces. I haven't tried it myself, though, so I can't tell you it won't work for what you want to do.
    Andrew Werby
    Website
    Jun 2012
    817
    You'll get some bounce from the belts on anything but light cutting forces. And as mentioned, gantry needs beefed up, better router, not plastic.
  1. Replies: 4
    Last Post: 12-06-2019, 07:16 AM
  2. Replies: 0
    Last Post: 10-18-2014, 05:50 AM
  3. X3 nut good design ?
    By ZipSnipe in forum X3/SX3/G0619/G0463
    Last Post: 04-07-2013, 08:15 PM
  4. Dual Plasma Router Table Design Concept Idea - Any Good?
    By NIC 77 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 06-11-2011, 04:58 AM
  5. Good logo design says it all
    By ovkris in forum Polls
    Last Post: 02-28-2011, 08:44 AM
