586,058 active members*
4,614 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Creating 'holding tabs' or 'bridges'...
Results 1 to 8 of 8
    Jan 2015
    24
    First - this is a CNC Wood Router and I am attempting to 'cut' an outlined piece of wood - yes... my guitar pick guard. My final expected piece will the be very curved outline, routed out of a piece of plastic with small 'tabs' or 'bridges' left at strategic places in outline which 'hold' the routed outline to the blank. I will remove the blank from the table, and then use a knife or some other cutting tool to to cut through the tabs which will free my routed pick guard free.
    I have my contour defined in DCAD. When I switch to DCAM to start creating the tool paths, there doesn't appear to be an option to create 'holding tabs' (little sections of the material that remain and span the routed gap so the actual outlined piece does not start moving around during the routing process). There is a 'bridge' function of course - but that appears to be method of connecting multiple contours together to create a single machine tool path. The DCAD Help file indicates that function - but that is not applicable to me - my outline is a single outline.
    It seems to me a 'workaround' would be to take my outline, create a second copy parallel to it - offset by at least my expected tool width. Then I have my two elements or contours that I could 'bridge' to create my holding tabs. That's a fine idea - but because this is an imported DXF and is VERY curved - these curves amount to a gazillion little straight lines. 'Selecting' just the outline and then trying to figure out how to 'stretch' it or otherwise create an offset 'parallel' outline of some dimension .25" (or greater) just seems ENORMOUS to me.
    Here is a 'picture' of the outline I am trying to route...
    Any ideas out there?
    Thanks!
    Arden
    (and I apologize for all the posts... Dolphin wants me to 'learn', 'use' and 'say good things'... right now - I'm at the 'learning' part - hopefully REALLY quickly to the 'use' part...)
    Sep 2013
    326
    Re: Creating 'holding tabs' or 'bridges'...
    Sorry I cannot be of more help. I',m pretty darn new too and what I'm reading is that holding tabs are something of a 'trial and error' but should be a button click option suggestion.
    I did find this.
    http://www.cnczone.com/forums/dolphi...ding-tabs.html
    Since this is more like 2.5D and similar to what I do with my Plasma CNC cutter I can tell you that SheetCAM will do what you are expecting with holding tabs, lead in/lead out etc. It also does nesting and many other things. I know your investment here is with this toolset. Just noting something very popular w/ us flameheads in the 2.5D space. It'll output the Gcode you need.
    Sep 2013
    326
    We'll this is an old old link to a ZIP file that does seem to explain how to do tabs but I have not been able to see the video. Only sound. Maybe it'll show on yours.
    Dolphin CADCAM > 2d Tabs on contour to hold part in blank - Page 2
    the Zip here: https://app.box.com/s/wvkq9idbzrr1nq5sm0ys
    Jan 2015
    24
    CountryGuy - you are a WEALTH of good information. I was able to download and view (and hear) the complete video. I had already resolved my issue by using a modification of the fellows solution - partial machining. My outline was a total of 776 segments around the outside. I created a number 'GoRound's each one being a partial machining where I 'skipped' a number of the short segments - thus leaving my tabs. The end result came out pretty nice. I THINK I attached the picture...
    Sep 2016
    10
    There's a video on youtube of how to do this. I've only tried it once. You can pick which part of your contour you want the tabs to be in and stop and start the contour to make the tabs.
    https://www.youtube.com/watch?v=-XHwadk0RaM
    Jan 2015
    24
    Thanks cjg - but I have already canned this useless software and moved onto other far more user friendly and affordable software. DolphinCAD has been one of THE most useless 'investments' I have made for this hobby of mine. They gave me a SUPER discount at $200 - and that has been WAAAAY too much for what it does and how it does it. My sympathies to anyone who got snookered into a full-price purchase.
    Am I bitter?? yes... I use commercial 'canned' software for a lot of things every day. I was doing CAD drawings on software before Windows was a glimmer in Bill Gates' eye, and those apps in the early 80's were far more intuitive than this software EVER was. Sorry Dolphin - there is no love lost for your software.
    Irwinger
    Apr 2003
    354
    Sent you a PM irwinger when you get a moment to read it.
    Milton in Tennessee ya'll!
    Nov 2013
    Quote Originally Posted by irwinger View Post
    If you don't mind, would you please share what software you moved onto?
  1. Creating holding tabs for profile cutting
    By sansbury in forum BobCad-Cam
    Last Post: 08-02-2013, 12:56 PM
  2. How to create bridges/tabs for milling
    By jaras in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-04-2010, 07:58 AM
  3. Holding tabs?
    By LessPaul in forum Dolphin CAD/CAM
    Last Post: 03-29-2010, 11:50 PM
  4. Holding Tabs
    By webgeek in forum EdgeCam
    Last Post: 01-26-2010, 08:22 PM
  5. Tools marks by tabs/bridges
    By bd007 in forum DIY CNC Router Table Machines
    Last Post: 01-19-2007, 03:33 AM
