In industrial dot positioning and measuring working fields, green alignment laser pointer is always the most visible, brightest dot alignment tool on the earth. It is always specially designed with portable pen style design. No matter what kind of dot targeting fields, it is just able to make quite stable and precise dot measurement on required working surfaces.
Green alignment laser pointer always adopts import 532nm green laser diode and glass coated cylindrical lens. In continuous line generating work, the green laser line will not break, decay or dim in practical use. The uniform distribution green laser line has just made the most precise and accurate line alignment result at both close and long distance line targeting.
When users are making long distance line generating with high powered green alignment laser pointer, users should be cautious enough with powerful laser radiation. In addition, users should always try to install proper targeting places so as to obtain the most satisfied dot positioning efficiently.
