586,379 active members*
3,806 visitors online*
    Apr 2015
    8
    Planing Aluminium (Newbie)
    Hi, I wonder if you kind souls will help out a New retired Chinese CNC user. I've bought an Aluminium Vacuum table which works fine for suction
    but needs a light planing to get accuracy on the Z plane. What if any bit should I use to achieve this and what speeds etc.. I'm happy engraving acrylic and wood but have never attempted alloys. The CNC is a 3040 and works well on small projects for home use. It has a 200 Watt spindle with approx 12000 revs.
    Thanks Fraxinus
    Nov 2012
    108
    Re: Planing Aluminium (Newbie)
    I would experiment with a scrap aluminium plate to start with.
    I assume you have an ER11 collet?
    I would use a 1 or 2 flute 1/4" carbide end mill, running at 12,000RPM and about 300mm/minute (faster if it's two flute). Stick to 50% stepover and take very shallow cuts -- maybe 0.1mm.
    I would use some WD-40 for lubricant.
    Apr 2015
    8
    Thank you TG I'll give it a try next week and get back with result:wave:
  1. NEWBIE: Cutters for T6061 T7075 Aluminium
    By Karl Magnus in forum European Club House
    Last Post: 04-21-2013, 03:09 AM
  2. 3D surface planing
    By pejaer in forum SprutCAM
    Last Post: 10-26-2012, 06:34 PM
  3. Plasma 4x4 Planing
    By CYRAX in forum Waterjet General Topics
    Last Post: 02-28-2012, 03:43 AM
  4. table planing trouble
    By Max Richards in forum Community Club House
    Last Post: 03-06-2007, 04:47 PM
  5. Newbie question: Cutting aluminium
    By RAN in forum MetalWork Discussion
    Last Post: 05-16-2005, 03:48 AM
