As the title states, I have, for better or worse practically inherited a Seiko D-Tran XM5000, an older cantilever, cartesian assembly robot.
Its working area is 600*400*200, and its resolution and repeatability for movements are boasted quite high in the manuals that I found.
I am almost dead set on starting to build it up as a router, unless you all see any red flags in the details below.
I have been exploring CNC builds and entry level machining for months, so this might get lengthy, but bear with me. Disclaimer this will be my first build!!!!!!
Here are the nitty grittys on this particular idea:
1. Deflection - Cantilever and Router certainly don't go in the same sentence together. However! The machine is industrial grade, cast iron constructed and designed for a 15KG payload. I won't be hogging steel, but 30 lbs seems to be enough to get away with aluminum. I was playing with an indicator this morning and it holds up well to vertical forces. (Within 0.01" when I'm really leaning on it) Thats really alright for me, but I really don't know how much force is transmitted during lateral operations, and how the thing will take it. The rails are beefy though, and the ballscrews are ground/high pitch. I'm impressed overall with the construction of this thing.
2. Tooling - Are those 4million RPM chinese spindle motors really any good? The collets look tiny, and have never seen someone doing any real damage with one. I read an interesting thread on AC Servo motors for a lathe spindle, why not for milling? Shooting for aluminum in terms of power torque speeds etc. Since the machine isn't as rigid as a VMC, maybe higher spindle speed and a little slower feed would help? This is where my lack of actual machining experience shines!:withstupi
3. Controls - The proprietary controller looks ancient. BUT I can get a working one if I need it. I'm tempted to steer away from this option for a few reasons. Its huge. Its old. And I have no idea how to mess with it. The PC interface software needs to be run on Win2000 or earlier, and is geared towards pick and place assembly work. How I will get it to accept commands from Mach3 (or similar), internally, I have no idea. I have a mechanical background and software is not my forte. The other extreme is replace both the motors and the controls with new, or like new, matching pairs for each axis. The plug and play aspect of this idea bodes well to me, BUT that looking at around 2-3 grand. How do I get these brushed DC servos running on a modern controller?? Seems to be a 600ct encoder with 6 wires coming from it. In all my research I find that mitsubishi motors like mitsubishi controls etc. This company, Tamagawa no longer supplies DC servo controls, atleast not on their website. Before I call someone up over there what are your immediate thoughts? Keep the motors or swap them. I would love to keep it under 1000 for electronics.
This last one is what I've really been thinking about lately and could use some guidance here for sure. Like I said I am a greenie so go easy on me. I've been doing my HW as best I can!!
Any feedback or comments would be greatly appreciated. You can find a picture of the machine if you google "Seiko XM5000" What do you think??:idea:
