586,075 active members*
4,035 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > Drip Feed HM-600 from DNC
    Apr 2015
    Hello
    What needs to be available on an OKK HM-600 Fanuc 160i control in order to Drip Feed from our DNC? Our CNC programs are starting to get too large to store in the control's memory.
    Thanks in Advance
    May 2012
    35
    Re: Drip Feed HM-600 from DNC
    You need a cable with hardware flow control wires. Of course, you need a software that can work in this mode.
    AGG Software. DNC Precision and CNC Syntax Editor software.
    Apr 2015
    Thanks for the info. Is there a specific setting on the control that tells the control not to load the program into control memory and that the program will be fed by DNC?
    Nov 2007
    352
    You can also use sub programs stored in a memory card and called using M198 !
    This expands the memory but runs at control speed instead of a DNC connection speed and alot cheaper
  1. DNC/Drip Feed
    By rsfairman in forum Fanuc
    Last Post: 03-06-2015, 11:24 PM
  2. Drip feed DNC
    By forhire in forum NCPlot G-Code editor / backplotter
    Last Post: 07-09-2011, 04:59 PM
  3. Drip feed or DNC
    By airlid in forum Mori Seiki Mills
    Last Post: 02-18-2010, 12:19 AM
  4. DNC-B to use drip feed
    By 78nova in forum Okuma
    Last Post: 02-02-2010, 08:21 AM
  5. Drip feed, DNC?
    By Greg_B in forum Mastercam
    Last Post: 05-20-2009, 05:31 AM
