586,043 active members*
3,574 visitors online*
    Apr 2015
    TM-1 320 Power Supply
    Hello:
    I'm having problems with the 320V Power Supply of a TM-1. On the machine's screen appears the alarm 292 and inside the control cabinet the power supply shows the digit "5".
    On the description of the alarm reads "AMP OUT / CHASSIS FAULT". Does anybody had this problem. Any help will be much appreciated.
    Thanks in advance.
    Apr 2003
    1873
    Re: TM-1 320 Power Supply
    Found this
    Alarm: 292 320V VD/MMPS FAULT
    Haas Alarm Description:
    320V VECTOR DRIVE OR MINI MILL POWER SUPPLY fault has occurred. This alarm is generated whenever a condition of over voltage, under voltage, short circuit, over temperature, or shorted regen occurs. This alarm should be followed by another alarm with a detailed explanation of the power supply condition. Press RESET key to continue. If RESET does not clear all alarms CYCLE POWER TO CONTINUE!!
    Apr 2015
    Thank you very much.
    Turn out that the problem was outside of the Power Supply. Was an earth problem.
    Feb 2010
    1184
    Quote Originally Posted by servicedB View Post
    Care to elaborate a liitle bit more?
    Earth ground problem?
    Earth rotation problem?
    Phasing of the moons?
    I have the same problem .If I start my machine it take betwen 5-25 minute .The same error.I tryed disconect axes , the spindle did work without error. Every axes on is error 292 and inside the control cabinet the power supply shows the digit "5".Please help .Can be broken Trafo?
  1. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  2. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  3. Power Supply/Power Cord Sizing for Four 850 oz-in Servos, One is Slaved
    By Plugger in forum CNC Machine Related Electronics
    Last Post: 03-11-2012, 05:52 AM
  4. FANUC Alpha Series power supply input power limits
    By tcom-frazzled in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2012, 06:07 PM
  5. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
