586,728 active members*
3,187 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Super Mini not homing properly
Results 1 to 7 of 7
    Oct 2012
    59
    Hello,
    I have a 2008 Haas S-Mini with series 16 software. For some reason when I walked away from my machine, I returned to a "NO X AXIS" error, I hit reset and got the " NO X ZERO" message displayed on start up before homing, I hit "power up restart" , Z and Y homed properly but X went in the complete opposite direction of factory home. It kept homing in the wrong direction until it could go no further, stopped and displayed "X AXIS TOO MUCH" .
    I am currently waiting on service but if anybody can tell me what is wrong, you would be the most Elite! I'm thinking X encoder or something to do with the X limit switch.
    Mar 2010
    1852
    Re: Super Mini not homing properly
    Chips on, or stuck X axis limit switch.
    Mike
    Feb 2010
    1184
    Quote Originally Posted by Machineit View Post
    Mike
    Yep! +1
    Jul 2005
    12177
    You have been told the cause of the problem but nobody mentioned how to get the X axis off the hard stop at the end of the ballscrew; I am guessing that is how the machine is sitting while you are waiting.. Power the machine up but DO NOT press auto restart. Go to Setting 53 JOG W/O ZERO RETURN and turn it on; right cursor, then WRITE (I think).
    Now be careful: Select Handle Jog and X axis and jog the axis away from the end of its travel. Watch the axis load display as you do this, it will spike up as you click the jog wheel but should settle back close to zero between clicks. If the load does not settle back check you are going the correct way. If you are going the correct way and the load keeps climbing wait for the service guy, something might be damaged.
    Oct 2012
    59
    Thanks for the prompt replies guys! Got in touch with a tech over the phone and he had the same thing to say...it was a chip on the X axis limit switch, (located approx. mid rear table just behind that first upper guard)
    Yes, setting 53(ON) does allow jogging without home first in .001 increments.
    Thank you all again I'm back in business!
    May 2009
    32
    Quote Originally Posted by haastec View Post
    Yep! +1
    I third that. Usually a chip On the sensor or a stuck home limit switch.
    Aug 2005
    5
    Quote Originally Posted by oshuab View Post
    Does anyone know just where to find the X Limit switch on the HAAS Mini Mill?
    When doing a power up restart, the table travels all the way to the left hitting the end of it's travel and then generating an X Limit error code.
    I believe the problem to be a stuck or bad switch.
    HELP!
  1. Super Mini Mill 2 vs Mini Mill Tool Tracking
    By Terry G in forum Haas Mills
    Last Post: 05-25-2014, 06:55 AM
  2. k40 laser not homing properly
    By dominic gailgan in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-03-2013, 10:56 AM
  3. Super mini mill pricing
    By ScottC in forum Haas Mills
    Last Post: 04-25-2011, 05:57 AM
  4. 2412s super mini
    By PBMW in forum Sharp CNC
    Last Post: 10-10-2007, 01:37 AM
  5. help with super mini mill please
    By daleman in forum Haas Mills
    Last Post: 08-14-2006, 08:32 PM
