586,655 active members*
2,311 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Bubbles in Mixture of Epoxy Resin
    Apr 2015
    Hello Everyone,
    my name is Simon and I am from Czech Republic.
    I want to Ask you about the Technical processing of Polymer Castings or Mineral Concrete. During my essay-project i have in my Cast very much bubbles. I mixed Resin, Harder, Sand, Dust, Stones - fill the Form and vibrated this Form, but all the same - Bubbles.
    Have you please a suggestion how i can remove the bubbles from this mixture? On vertical sides have i still more bubbles. Very thanks for Answer and wish you nice day.
    Best regards
    Simon
    Jun 2010
    4256
    Re: Bubbles in Mixture of Epoxy Resin
    One way is to use some sort of vacuum pump to suck all the bubbles out.
    Some practice runs first are advised: you have limited time when you have mixed the epoxy.
    Cheers
  1. Machining an Epoxy Resin Table Top
    By CNC-Dude in forum Material Machining Solutions
    Last Post: 12-17-2015, 04:15 PM
  2. PU Polyurethane resin / Epoxy alternative
    By yellow_submarin in forum Epoxy Granite
    Last Post: 07-23-2012, 10:06 PM
  3. choosing the correct epoxy resin
    By jerrywi in forum Momus Design CNC plans
    Last Post: 04-07-2012, 02:23 PM
  4. Epoxy resin and Silicone Rubber mold help
    By Ikaros in forum Moldmaking
    Last Post: 08-23-2011, 12:18 PM
  5. Epoxy resin floor paint and MDF.
    By Oldmanandhistoy in forum DIY CNC Router Table Machines
    Last Post: 02-25-2006, 09:09 PM
