586,287 active members*
4,052 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki MSG 501 Fanuc 18 iTA - PCMDI language parameter
Page 1 of 2 12
Results 1 to 20 of 26
    Apr 2015
    18
    Question Mori Seiki MSG 501 Fanuc 18 iTA - PCMDI language parameter
    Hello
    We changed 3102 but it was only change fanuc side language.
    Does anyone know the language change parameter of the PCMDI (Mori-Seiki side)?
    Any help would be very grateful.
    Feb 2009
    6028
    Re: Mori Seiki MSG 501 Fanuc 18 iTA - PCMDI language parameter
    What language do you want?
    Should be keep relay 20 for alarm language but check YOUR ladder to make sure
    Attached Thumbnails Attached Thumbnails ladderlanguage.pdf
    Feb 2009
    6028
    If you wish to have the MAPPS panel in a different language, you will need to contact your dealer and have them come out to install the correct language version of software.
    Apr 2015
    18
    hello,
    i need English language,
    and no mapps,
    need only PCMDI screen. it is containing magazine , atc manual operation and turnmill offset page, load monitoring etc.
    I will try your suggestion. thanks
    sorry for my English.
    Apr 2015
    18
    keep relay 20 are all zero, there is no effect.
    Feb 2009
    6028
    Pretty sure MSG 501 IS a mapps control. MSC was not. Sould be Mapps 1. Those are software driven, in fact during instalation of the software it never asked what language, so i think the software is specific for the region. This will get expensive i think. You will need to regester the machine with Mori Seiki (you will need to do this if you ever want to order parts anyways) then have the service tech come out with the proper mapps version and load it in to the machine. The keep relay is only for alarm messages.
    Apr 2015
    18
    keeprelay 20 not affect to alarm or something.
    thanks
    Aug 2011
    2517
    take photos of the screens and post here. if they are accessed with the custom button some of them were Fanuc screens and can probably be changed.
    on my MAPPS the language is set in one of the INI files and depending on what MAPPS version you have and what language and files you have now it may be possible to just copy across and replace one file from an English version of the MAPPS software.
    But first take photos of the screens so we can see what they belong to (Fanuc side or MAPPS side)
    Also if you can manage it, take out the PCMCIA card from the MAPPS unit, put it into a laptop and copy out a directory of all the files in a DOS command prompt by typing DIR /S > LIST.TXT
    then post the file LIST.TXT here. This will tell us what language files you have now.
    Feb 2009
    6028
    He sent me a message saying in fact its a MSC control, so no mapps. Just a keep relay setting.
    Apr 2015
    18
    it is msc 501.
    subject was wrong. sorry.
    Feb 2009
    6028
    Its all in the back of the ladder book.
    Apr 2015
    18
    Quote Originally Posted by underthetire View Post
    Where can i find the ladder book?
    Feb 2009
    6028
    If your machine did not come with one, you will need to order one from Mori. They are machine specific.
    Apr 2015
    18
    hello
    pcmdi language issue Solved
    solution:
    1- enter the pc mdi screen
    2- hit the number keys "95" and input
    3- a screen message appear ( enter DATA
    4- write "196" and input
    5- D data 196 will appear on the screen
    there is 7 bits
    and all must be zero (0)
    0 input
    and save.
    voila!
    Apr 2015
    18
    but, allarma language still in japanese
    there ie no infor about that.
    thanks
    Aug 2011
    2517
    Keep Relay parameter K20 bits 0 and 1 probably need to be changed
    bit 0 = 0 With Language Select for Alarms
    bit 0 = 1 Without Language Select for Alarms
    bit 1 = 0 With Other Language
    bit 1 = 1 Alarms are English or Japanese
    the bits 2,3,4,5 should be all 0 but if ONE of them has a 1 it is used to set the language german, french, spanish, italian (in that order bits 2,3,4,5)
    Please tell us what settings you have in K20
    You may need to check your Fanuc parameter for language too.... 9924.0 to .7
    Apr 2015
    18
    hello
    K20 is all Zero,
    param 9924 was 0bit=1
    I changed 0bit to zero and system restart
    no effect for alarm.
    fanuc side English, PCMDI side English.
    only alarm ((
    thanks for your helps
    Aug 2011
    2517
    9924.0 is 1 for Japanese language so it should probably be 0 anyway. English = 9924 all bits are 0
    For english alarms K20 bit 1 should be 1
    K20 bit 0 could be either 1 or 0. probably should be 1 but the use isn't clear (i.e. "without language select" means what? it's fixed at English or Japanese or something else? Don't know exactly....)
    K20 should be 00000010 or 00000011
    try both ways and report back here with your findings. power machine off/on to test it after changing K20
    Apr 2015
    18
    I've tried both way with power off/on.
    EX alarms still japanese.
    Aug 2011
    2517
    Your machine may be different. Those parameters were from MSG-500 21iTA
    Do you have the ladder diagram manual? The PMC parameters are listed at the back.
Page 1 of 2 12
  1. Need parameter for Mori Seiki DL-15 with Fanuc 16TT
    By greenery_fr in forum Mori Seiki lathes
    Last Post: 06-17-2022, 12:49 AM
  2. parameter back up for mori seiki zl45 fanuc OTTC
    By Asfar in forum Mori Seiki lathes
    Last Post: 01-27-2012, 09:56 AM
  3. CNC LATHE MORI SEIKI Diagnostic Parameter
    By suleman_mani in forum Fanuc
    Last Post: 05-19-2008, 08:47 AM
