586,058 active members*
4,716 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > Micro resistance/spot welding copper to brass
    Apr 2015
    I'm trying to either build or buy a resistance welder to weld a small copper rod (0.03" diameter x 1" long) to a piece of brass sheet. The weld would be at the end of the copper rod.
    My research suggests that a capacitivedischarge welder would be what I need.
    If anyone has any idea on what power range I should be looking for?
    I have seen these battery tab welders on ebay but I'm not sure they would be what I need. - Updated Hand Held Spot Welder Welding Machine Laptop Mobilephone Battery 220V | eBay
    Any suggestions appreciated! =) Thank you.
    24221
    Re: Micro resistance/spot welding copper to brass
    Resistance welding generally refers to high current low voltage for Ferrous metal.
    A capacitive discharge is similar but stores a high DC voltage in a capacitor bank for a stud welding etc. I have not seen it used with two dissimilar non-ferrous metals however.
    I believe what you need for bonding copper to brass is either braze or silver solder and a small flame source.
    Al.
    Albert E.
    Apr 2004
    5737
    I don't think that will work either. Drill the brass sheet to a press-fit for the rods and drive them in. If it needs more holding power, use silver solder.
    Andrew Werby
    Juxtamorph.com
    Dec 2015
    7
    it's an interesting question, i will try to find answer of your question then i will surely tell you.
    Jan 2015
    138
    I just built a resistance soldering unit. I found a 56A, 5VAC transformer at a hamfest and combined it with a Variac. If you do this, measure the primary current with the output shorted to figure out what size Variac. In my case I'm using a sharpened carbon rod to apply the voltage to the work; I don't want the electrode to weld to the jewellery.
    I suspect it would work fine to weld the size rod you describe, but haven't tried that. When I short the carbon electrode to a bolt head, it gives a nice carbon arc.
    What would definitely work with one of these is to use silver solder. I agree with Andrew that you will have a much better joint if you drill a hole in the brass. I don't know about press fitting a 0.03" rod, that sounds a little problematic. Just doing a butt join seems weak.
    Steve
  1. spot laser welding machine
    By hanzlaser in forum News Announcements
    Last Post: 03-09-2012, 02:17 PM
  2. spot welding
    By [email protected] in forum Welding Brazing Soldering Sealing
    Last Post: 05-26-2008, 03:41 AM
  3. spot welding
    By mog5858 in forum Welding Brazing Soldering Sealing
    Last Post: 03-10-2008, 08:45 PM
  4. Spot welding ???
    By skipperspride in forum Welding Brazing Soldering Sealing
    Last Post: 02-17-2008, 06:27 AM
