Originally Posted by
dj_nexxus
So it has been over a year since I got a prototype dremel based cnc working, and had to dismantle it, but I have now decided to create a larger medium sized CNC with a main view of machining aluminum with some wood in between and I may even want to explore the prospect of milling steel With that said, I am waiting right now to place the order for my set of Chinese ball screws and SBR20 Rails and blocks. My gantry supports and Z-axis will be made from 3/4" Aluminum 6061 plate and the remainder of the frame from 8020 aluminum profile, I will post CAD pics and specs on the framing as we go along. but for now I have begun work on the aluminum plate. Without ready access to a machine shop or certain tools, I am left with doing alot of the work manually, the pics to follow will show the gantry supports and the plate I used to create the Z axis, I cut the plate using a basic hacksaw and will have to file the plates to clean them up to a presentable level.
