586,102 active members*
2,543 visitors online*
Results 1 to 6 of 6
    Mar 2015
    10
    Nema23 weight limit
    I just received 2.2KW water cooled spindle.
    It weights 4.8 kg. Friend of my made me new mount in aluminum that weights 2.8 kg.
    Old router was only half kg.
    So i will be adding 6.5 kg of weight to my z-axis. Is this going to be too much for Nema23 270oz motor?
    I tried moving z with new weight manually through mach3 and it works fine, but not sure what are the remedies if any on the longer run.
    Any input will be highly appreciated.
    Apr 2004
    5737
    Re: Nema23 weight limit
    It sounds like it does work. What are you worried about? The most likely issue is that the spindle will drop when the power's turned off. To combat that, you can set up a counterweight, use springs, or gas struts to offset the added weight.
    Andrew Werby
    Website
    1695
    I have no problem lifting a 115lb milling head, using a ball screw and a 280oz in motor.
    Mar 2015
    10
    I do have spring.
    115lb, I guess i should be fine.
    Thank You.
    Apr 2006
    118
    Quote Originally Posted by H500 View Post
    Hi H500, Is the motor direct drive to the lead screw or is there a gear reduction?
    1695
    Quote Originally Posted by cstmwrks View Post
    I am using a 5 turn / inch ball screw and a 1.6x gear reduction for the z axis. I'm using a gas cylinder, but it is not needed for my speed setting of 100ipm. It's main purpose is to prevent the head from sliding down when power is removed.
  1. Nema23 for Z-axis
    By Scalpel78 in forum Stepper Motors / Drives
    Last Post: 01-23-2015, 01:43 AM
  2. tool weight limit?
    By cncworkdork in forum Multicam Machines
    Last Post: 02-07-2014, 06:35 PM
  3. Replies: 0
    Last Post: 11-28-2012, 06:39 PM
  4. NEMA23 steppers getting very hot
    By Angelos in forum CNC Machine Related Electronics
    Last Post: 04-02-2004, 05:00 PM
  5. Nema23 vs 34
    By boxwood in forum DIY CNC Router Table Machines
    Last Post: 08-09-2003, 01:14 AM
