586,116 active members*
3,469 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > need help for arduino programming
    Jan 2015
    5
    who can help me to make the ( software ,firmware) of fab@home 3d printer compatible with :
    -Arduino
    -easy driver
    -nema motor
    knowing that the software and the source code is available at the following address:
    Fab@Home:Model 1 Firmware - Fab @ Home
    Model 2 Software - Fab @ Home
    Fab@Home:Electronics - Fab @ Home
    Thank you
    Apr 2006
    118
    Re: need help for arduino programming
    I know the Arduino can run any size stepper via a driver. But running 3 motors at the same time I think would be out of it's ability. You can see some examples with Arduino and Easy Driver at EasyDriverExamples.html
    Feb 2013
    39
    Grbl does that quite handily; https://github.com/grbl/grbl/wiki
  1. Arduino controlled THC
    By rbmgf7 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-26-2015, 09:36 PM
  2. Arduino CNC set-up
    By Palladin54 in forum DIY CNC Router Table Machines
    Last Post: 09-20-2014, 09:25 PM
  3. Arduino Modbus?
    By wbrandsmeier in forum Mach Software (ArtSoft software)
    Last Post: 02-01-2014, 07:47 PM
  4. EMC with Arduino for USB I/O?
    By sansbury in forum LinuxCNC (formerly EMC2)
    Last Post: 05-05-2012, 09:27 PM
  5. Arduino
    By LTP in forum CNC Machine Related Electronics
    Last Post: 02-11-2011, 10:26 AM
