That sounds like a tough problem. Is that a machined Tslot, or just a cast T slot? The best thing to do is to weld up the broken areas. You might be able to form a piece of graphite to slip into the Tslot as a backer for the welding puddle. Otherwise, you'll have to remill the Tslot. Use a machinable nickel alloy filler rod.
