586,067 active members*
5,130 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > recomend cad/cam software for sculpture prof
    Jun 2005
    14
    I am looking for recomendations for cad and cam software. I am a sculptor and professor so I would qualify for and educational discounts. Currently I have a sherline mill I have converted to cnc via xylotex and mach3 and I have nearly finished building a cnc router. I intend to do a lot of work scanning objects via a touch probe I have set up for both the mill and router, and I am particullary interested in digitizing objects, combining them on the computer, and then outputing back to the mill or router. I do have a grant to pay for some of my indulcences with this, but the less I send on software, the more I will have to spend on delrin, wood, alumnum. . .
    I have little a experince with 3d modeling software, and no experince with cam software, so the ability to be able to read books and easy to find support is important.
    thanks in advance
    -barry
    Apr 2003
    1357
    You may want to look at Rhino, and either RhinoCam or VisualMill from Mecsoft.
    Rhino has the ability to import points from a variety of touch probes (MicroScribe, Faro etc.).
    The Mecsoft products are well supported, from what I have observed.
    www.rhino3d.com
    www.mecsoft.com
    Dan
    Jun 2003
    2103
    You might also want to look at Madcam as the cam for your new Rhino!
    Mike
    No greater love can a man have than this, that he give his life for a friend.
    If you want tp try a 3D modeller that actually works a little like sculpting, check out Silo at www.nevercenter.com.
    But, I'll agree with the others that Rhino will probably be your best bet for bringing in digitised models.
