Hey guys, I've been a long time lurker of this site but I don't make many posts. I am considering building a CNC plasma table for my own personal hobby/use. I bought an old Quincy 325 compressor that I am going to be rebuilding in hopes of using it for the plasma cutter. I was curious as to how the smoke would be using a water table plasma? It will be going into a double car garage, so the space is fairly small considering. Should I be looking to put a large exhaust fan in before I get started in order to deal with the fumes/smoke?
Onto the design considerations. I have an OK grasp on how the machine works, but there is a few details I am unclear about. The whole floating head design is a bit of a mystery to me. This was the best video I could find showing somewhat how it works:
So when a cut is being made, the plasma torch and head are literally held down by gravity alone? What is the advantage of having it float like this as well as having a moving z axis?
The other question I have is in regards to rack and pinion motion versus synchronous belts. The rack and pinion looks more robust, but might be affected by debris depending on how it was mounted. It would also need some sort of automatic tension to keep the backlash to a minimum. The belt system looks "cool", but what is the advantage to using this system of the rack? I would be concerned with the belts stretching causing off positional errors as its accelerating/decelerating?
I am in no rush to build a machine, as I have a few other things to deal with in preparation for the project, but I would really like to get started on designing/modeling it. My idea was to make a 4x4 table, that could be upgraded to something larger down the road if needed. I was hoping to incorporate some form of pinning/locating so that If I had to do something larger then 4x4, I could index a sheet through the machine. Thoughts on this idea? Is there any features that you would have incorporated into your machine that you didn't at the time of build?
As for budget, I was hoping to keep it under the $5000 mark with the plasma cutter. I would like a fully welded frame with water table, and 3 axis motion, with torch height control. Is this budget reasonable for something along these lines?
Ryan
