586,069 active members*
3,554 visitors online*
Results 1 to 8 of 8
    Dec 2007
    72
    Taig Headstock ER32 conversion
    Has anyone bought or converted a Taig headstock to ER32 Collet
    I just sourced the parts and will post results below
    Could have bought this but I think making one would be cheaper ,
    I also want to integrate the factory 6 step pulley on to the conversion .
    Taig ER32 Spindle Headstock - BB6Corp
    ER32 Spindle - New C25 ER32 150L Straight Shank Collet Chuck 25mm Extension Toolholder CNC Mill | eBay.
    Factory bearings are 40mm in dia I will have to line bore the head to 42mm to accommodate
    the 25mm x 42mm bearings to fit spindle , the sky is the limit when getting bearings - these can
    be as cheep as $3.00 all the way up to $150.00 for full ceramics .
    6905 2RS AB Alternator Bearing 25x42x9 SEALED Ball Bearings 17244 | eBay
    Dec 2007
    72
    Re: Taig Headstock ER32 conversion
    The finished ptoduct and here are the pictures on how I approached this , I had to use the Taig bearing spacer as a adapter to fasten the headstock to the 4 axis to mill the new 42mm bearing slots . Run out on the finished head is 1.5/1000 over the span of 3.0 inches which I can live with .
    Dec 2007
    72
    Total cost of me complete conversion was less than a $100.00 .
    I have ordered another ER32 & ER25 collet chucks but with a shorter 100mm shaft and on a 20mm diameter shaft .The first crack at this I used a 150mm x 25mm chuck which I had to shorten by 50mm but you learn from your attemps . These new units will house a thicker bearing but with the same 42mm OD . Also two more bare headstocks from Nick Carter .
    This is what the conversion will be used for - The ER16 takes a maximum of a 10mm shaft but the ER32 go all the way up to 22mm which gives me a little more elbow room on thicker shafted couplers .
    https://www.youtube.com/watch?v=YTaiG_cs178
    https://www.youtube.com/watch?v=zC57C04BCxM
    Jul 2005
    49
    Peter,
    That looks really nice!
    How are you retaining the ER adapter axially to the headstock? Are you using any preload on it?
    -steve
    Dec 2007
    72
    Quote Originally Posted by 900steve View Post
    Peter,
    -steve
    Hello Steve and thank you
    No preload on this one as it has 4 bearings and they were a tight fit on the shaft , I cannot feel any lateral give so every thing is very tight but I have since
    made another ER32 and ER25 headstock but with a smaller 20mm shaft and with a larger bearing in both. Fitment is not quite as tight so this allowed me
    to place an rubber O-ring in between the rear pulley and bearing and preload set that way . Everything on these very tight with absolutely no measurable play .
    Picture of The ER16 , ER25 , ER32 Taig heastocks + the first ER32 unit stil on lathe .
    Jul 2005
    49
    Very cool! Good to know. Have you used any of your conversions on the Taig mill?
    Dec 2007
    72
    Not as of yet but I will be eventually fitting the ER25 headstock on the mill as to use a .500 inch high helix carbide - aluminum cutter bit .
    Mar 2013
    Did you bore/drill out the C25-ER32-100L? Isn't the manufactured ID 14mm?
  1. Taig Headstock 4th Axis Conversion
    By antiretrograde in forum Taig Mills / Lathes
    Last Post: 08-05-2022, 10:38 AM
  2. Taig headstock falls
    By littleCNCjohn in forum Benchtop Machines
    Last Post: 08-30-2011, 01:43 PM
  3. MT1 into taig headstock
    By chris123 in forum Taig Mills / Lathes
    Last Post: 10-19-2010, 12:16 PM
  4. Raising Taig headstock
    By MechanoMan in forum Taig Mills / Lathes
    Last Post: 04-14-2009, 10:29 PM
  5. Taig Headstock Improvements??
    By scubasteve_911 in forum Taig Mills / Lathes
    Last Post: 08-22-2007, 06:10 PM
