586,102 active members*
2,658 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 500 linear guidway grease recommendations...
Results 1 to 6 of 6
    Apr 2007
    2580
    I have been using the grease that I received with the machine and it has lasted awhile now. Unfortunately I cannot read the information on the tube after I removed it from the grease gun to order more. Can someone please recommend me or give me the factory recommended grease for the axis way zirks on the Arrow 500? Thanks in advance..
    Pete
    Mar 2011
    463
    Re: Arrow 500 linear guidway grease recommendations...
    It should be in your service Manual, but I believe Cincinnati spec was P-64 which would be a Lithium Base grease. Something like a Mobilith AW2 or No. 2 Lithium.
    Apr 2010
    38
    Looked in the service manual for sabre 750 cnc mills. They recommend MobilLux EP2 . Just so happens it was the same grease that a Oil tech at a local distributor suggested .He said if you are not sure what you have been using , just make sure to purge the line enough until you see the new grease coming thru. Perhaps a little hard on the ways that are under the covers that you cant see.
    And the 8 pack of tubes was only $34.95
    Hope this helps
    Apr 2005
    1268
    Hey Pete!
    How Ya Been?
    Been awhile and was just thinking of you the other day. I was looking for a pattern for a rifle stock for a remington 700 target rifle and was remembering your air rifle! That was sure nice!
    Hope you've been staying busy!
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Apr 2007
    2580
    Quote Originally Posted by Slick27 View Post
    Hope this helps
    Thanks Slick will get some ordered. Appreciate it guys..
    Apr 2007
    2580
    Quote Originally Posted by bill south View Post
    Hey Pete!
    How Ya Been?
    Bill
    Hey bill,
    Sorrry for the delay in responding. For some reason the zone did not alert me to responses I need to check my settings. Yeah I sold that air rifle awhile back unfortunately. Now I am working on a few more custom stocks from laminate blanks. Never made one for a 700 Rem tho. Good luck man!! Peace
    Pete
  1. SBR20 Linear slide rails - Grease or Oil?
    By Semus in forum Linear and Rotary Motion
    Last Post: 02-11-2015, 02:52 AM
  2. Recommended grease for Linear rail truck bearings
    By mlabruyere in forum DIY CNC Router Table Machines
    Last Post: 09-13-2014, 07:19 PM
  3. Need recommendations for table saw linear actuator
    By stpeter in forum Linear and Rotary Motion
    Last Post: 04-15-2011, 05:33 AM
  4. Square Linear Guides and Rails, recommendations
    By Lappy in forum Australia, New Zealand Club House
    Last Post: 10-06-2010, 10:29 AM
  5. Linear bearing grease
    By Claude Boudreau in forum Linear and Rotary Motion
    Last Post: 04-11-2008, 05:33 AM
