Hello,
One year ago I decided to built the first laser machine in Greece.
The laser source is from Rofin and the model is SCx30w.
I made all the construction. The working table is 2100 * 2500 mm and there are 3 axis offcourse.
Unfortunately for me, Greece is a few years back in technology and they do not know lot of things about CNC and laser machines.
Anyway, the movement is from Bosch rexforth but not the servo drives but the railways. The servo motors are from SEM if you know it and the other part which goes with the servo is from Atlanta company. Anyway I dont think that all this might help for the problem I have now.
Everything is ok, but the main problem is the CNC. What I mean is, my PLC or controller if you say so, is ECKELMANN and the servo drives is from METRONIX.
The first problem that I have is that when the laser cuts a circle or a rectangle there are PERFECT!!!!! BUT! when I have a curve or an arc or an spline or anything else except circle and lines, the cutting quality is very bad! it cuts small lines, I dont know if you understand what I am trying to say for eg. when we have the letter S for example in the place that there are curves it will cut with the direction of a curve but when you look at it there are many big or small lines. I believe that the problem is from G code, but nobody knows.
My father built this machine and I am his daughter and Im so sad that we cannot figure this out. I am reading lots of things and Im trying to help him because the people who made the CNC installation they dont have a clue!!!
Anyway, is anyone have any idea about the problem I said? Offcourse this is not just one problem we have lots of problems.
I'll try to show you some pictures of the machine.
When we started making this machine we didn't thought it would be so difficult on the electronics part. Also the software is a huge matter too. We use SheetCam, it is ok but it is not enough for us.
The laser is working but not on the right way.
I will wait for any idea or any question that you might have.
CNC ZONE is my last hope!
Thank you,
Alice
