586,036 active members*
3,780 visitors online*
Results 1 to 7 of 7
    Jun 2012
    817
    New to lasers
    I am beginning the planning stage of a DIY CNC laser build. The sole use for this machine will be to cut slots in .050" or thinner paper tubing.
    I need help as to what type of laser and power do I need? I'd prefer to use a diode if that will do the job effectively, and if that will work, what diode to buy regarding power and wavelength? And recommended sources to purchase the parts, preferably all from one source.
    So can a diode do this effectively?
    Jun 2012
    817
    Re: New to lasers
    Feb 2007
    711
    Re: New to lasers
    Here is one I have considered.
    Industrial 808nm 2000mW Infrared Focusable Laser Diode Module Cutter w TTL | eBay
    I want something I can just plug in to a power supply and mount to my router.
    I think most cutting lasers are infrared? Maybe?
    Jun 2012
    817
    Re: New to lasers
    Quote Originally Posted by alan_3301 View Post
    That does look like it might do the job. I'm concerned about the cutting speed though. I've seen these diode lasers needing multiple passes to cut through material. The kraft paper tubing we use is .050" thick cardboard and if it takes more than 10 minutes to cut a few slots, it is not a viable option. I just don't want to buy a bunch of stuff to find out it won't work the way I planned because of my inexperience.
    We've been milling the pockets, but I don't like the fuzz it leaves. Maybe I could mill the pockets and then burn the fuzz off with the laser. That'd be pretty trick.
    Jun 2012
    817
    Re: New to lasers
    I'm not totally against going with a tube laser. Does anyone sell plans for the tube style laser cutters? I'm not interested in buying a kit, but I would purchase a planset if for nothing else to learn how they go together regarding mirrors and optics, cooling etc. Or any good resource that I can use to learn this stuff without wading through a million different posts here.
    Feb 2009
    6028
    Re: New to lasers
    I think the 2 watt would work fine, but you may need to make a nozzle for it so you could use air assist.
    Jun 2012
    817
    Re: New to lasers
    Quote Originally Posted by underthetire View Post
    Thanks for the input! Machining a nozzle and providing compressed air would be no problem.
  1. New to Lasers
    By JUNKYCOSMO in forum LaserCut
    Last Post: 03-24-2015, 08:07 PM
  2. Different lasers
    By Artworldcn03 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-05-2011, 01:24 PM
  3. Lasers
    By LeonD in forum DynaTorch
    Last Post: 11-25-2009, 08:42 PM
  4. New to lasers
    By 918rbennett in forum Community Club House
    Last Post: 09-24-2009, 01:31 AM
  5. Lasers
    By Appalachiatools in forum CNC Machine Related Electronics
    Last Post: 05-05-2009, 11:39 AM
