586,055 active members*
4,376 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Removing pinion from CNCRouterParts.com rack and pinion drive unit
    Feb 2007
    26
    Hi all,
    I am finalizing my design for my cnc machine and will be using the cncrouterparts.com nema34 drive units for my longest axis.
    Is it possible to remove the small pinion from the large pinion on this unit and replace it with another type such as one that works with a MOD1 rack?
    This would save me a lot of money in materials and freight if it is possible.
    Thanks.
    Brenton
    Sent from my iPad using Tapatalk
    Feb 2007
    26
    Re: Removing pinion from CNCRouterParts.com rack and pinion drive unit
    Surely someone has removed the smaller pinion from this setup?
    Mar 2008
    57
    I checked mine, and it looks like it's one piece. Might be easier to try to change the gearing on the other end to match what you want?
    Feb 2004
    1086
    These units are made from multiple parts, but are not easy to disassemble, and have a custom gear with a keyway that keeps the pulley and gear rotating together. Brenton, feel free to contact us directly for some options. Personally I'd be surprised if making 3 custom Mod 1 gears is going to be less expensive than just shipping to the matching gear rack to you.
    Best regards,
    Ahren
    CNCRouterParts
  1. calculatiing pinion size for rack and pinion setup
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 08-06-2015, 11:18 AM
  2. cncrouterparts 34 nema rack and pinion drive
    By Dan911 in forum Avid CNC
    Last Post: 08-06-2014, 10:40 PM
  3. Torchmate Upgrade to CNCRouterparts Rack & Pinion
    By jmusser15 in forum Linear and Rotary Motion
    Last Post: 05-01-2012, 03:26 AM
  4. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  5. Need help calculating steps per unit (rack and pinion)
    By idtkid in forum Mach Software (ArtSoft software)
    Last Post: 04-27-2009, 07:06 PM
