586,094 active members*
4,205 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > artcam to mach3 engraving problem
    Jul 2007
    8
    I've been trying to carve some words onto a piece of timber using a 32mm 60 degree V bit and when I design and simulate in Artcam Express everything looks ok, but when I open the tap file in Mach3 and simulate run time it keeps coming up with "radius error start of radius arc is different to finish radius arc". I'm also getting the same problem when I try to use a V bit to profile along a vector in any artwork that I load (doesn't happen when I use end mill or ball nose bits), am I missing something?
    Re: artcam to mach3 engraving problem
    Try changing the IJ mode in Mach3's General Config.
    Dec 2011
    59
    Gerry is correct switch the ij mode to incremental.
    you must be on an old version & post as the mach3/4 post p forces the change in mach
    Gary
    Beckwith Decor Products
    ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
    Jul 2007
    8
    thanks for the heads up , it worked a treat. sorry for late reply it's been a long time since I visited this site for help and I've forgotten where to post etc.
  1. control dsp ??????? mach3?,artcam?
    By andrescarrillo in forum Controller & Computer Solutions
    Last Post: 07-07-2013, 08:46 PM
  2. can artcam Engraving very small text in toolpath
    By coykiesaol in forum Jewelry Design Software
    Last Post: 02-13-2013, 05:36 AM
  3. Artcam/Mach3 Problem
    By breathe in forum Open Source CNC Machine Designs
    Last Post: 01-10-2011, 01:15 PM
  4. ArtCam Pro and Mach3
    By AngelT in forum ArtCam Pro
    Last Post: 08-19-2008, 04:56 PM
