586,106 active members*
2,945 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Multipurpose tool holder (Rhombic insert) for both face and z-axis cutting
    Jun 2008
    113
    Hello all.
    We are looking for a tool holder to which you can attach two rhombic insers, one like in this: http://www.ingersoll-imc.com/product...ombic_draw.gif
    and the other like this: http://www.ingersoll-imc.com/product...mbic_draw2.gif
    You could then do both radial and axial cutting with the same tool using all cutting edges of the insert.
    Where can I order one?
    Thank you very much.
    Korloy do these tools have a look on the web for the local agents
    Re: Multipurpose tool holder (Rhombic insert) for both face and z-axis cutting
    Try Sandvik Coromant . DCLNR/L [ size b ][ insert size ]and DCKNR/L . download the general turning catalog and look around page A 137 .
    Using Tapatalk
    Dec 2008
    3109
    Forget using a 80° CNMG type tip, you can't use all points....only 1/2 of them
    I suggest looking at a "Trigon" type of tip......, 6 usable points per tip ( Negative rake holder ) Link to Iscar Ecat
    Many manufacturers are around..... Iscar, Seco, Sandvik, etc
  1. Lathe insert tool holder size question
    By lcvette in forum EMCO Lathe
    Last Post: 01-15-2015, 08:19 PM
  2. thru-coolant tool holder for WNMG 432 insert
    By schwinn83 in forum Want To Buy...Need help!
    Last Post: 07-19-2013, 05:07 PM
  3. Tool holder for cutting tapered threads?
    By 67Charger in forum CNC Tooling
    Last Post: 01-16-2012, 11:24 AM
