586,119 active members*
3,618 visitors online*
    Jan 2013
    31
    CNC foam cutting question.
    Hi
    I have a CNC router from Romaxx link below. I am looking to cut close cell gray foam like you would find in a pelican case, does anyone make anything to use with a regular cnc router or do i need to just track down some long end mills.
    Romaxx CNC Router HS-1 machine a CNC workhorse | Romaxx CNC Router Systems
    Jan 2007
    175
    Re: CNC foam cutting question.
    It's more common to use hot wire or knife cutting for foam, if you want to re-produce the same shape ( peaks and valleys ) like those foam cases it's done with a knife in between two pin rollers, called Convoluted Foam
    Rockcliff Machine Inc.
    http://www.rockcliffmachine.com
    Jan 2013
    31
    Quote Originally Posted by rockcliff View Post
    Thanks for the info... I guess i need to look into making a hot wire machine since i really don't want to chance a fire in my laser machine. Got any suggestions for DIY kits?
    Jan 2007
    175
    For a hot wire cutter you basically need 3 things nichrome wire, an ac power transformer, and some mounting brackets, for all my hot wire needs I use these guys, Products for Industry, Laboratories and Hobbies
    Normally with most cnc hot wire cutters the wire is horizontal, but I have rigged up stuff for a cnc router with the wire vertical, and did the cutting off the cnc router in front
    Have no worries you can burn your place down to the ground just as good with a hot wire cutter (flame2)
  1. RCH2030 CNC Cutting machines /Chinese cutting machine for foam
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 12-25-2014, 07:58 AM
  2. Cutting EVA foam
    By mrclaybo in forum Material Machining Solutions
    Last Post: 11-26-2012, 03:54 PM
  3. Looking for someone to do some foam cutting
    By DanielHice in forum Community Club House
    Last Post: 02-26-2010, 02:48 PM
  4. Foam cutting question
    By haripatel in forum CNC Wire Foam Cutter Machines
    Last Post: 11-15-2006, 04:33 AM
  5. Need help with foam cutting
    By Spitfire in forum CNC Wire Foam Cutter Machines
    Last Post: 09-07-2005, 05:31 PM
