I am having trouble programming a job that has 16 raised squares. So I need to mill around each square. I thought through G code, I could center over the first one, then call out G92 X0Y0 Then program the actual dimensions from the center. Then move over the appropriate and G92 that location and start again. problem is, the tool offset does not seem to agree with the G92. Here is the program. just copied the first row so that you can see what is going on. Any advice would be appreciated.
Thanks Mike
(20687 HOT KNIFE CHUCK)
(PROG.1)
(05-08-15 M.R.E.)
N100G90G80G40G0
T1M6(.125DIA END MILL)
G54X1.1196Y-1.1196S4500M3
M8
G43Z.1H1
G92X0Y0
X-.2Y.5
G1Z-.03F5.
G41Y.1422D1
X.13
G2X.1422Y.13R.0122
G1Y-.13
G2X.13Y-.1422R.0122
G1X-.13
G2X-.1422Y-.13R.0122
G1Y.13
G2X-.13Y.1422R.0122
G1X.15
G40Y.21
G90G0Z.1
X.4203Y0
G92X0Y0
X0Y.21
G1Z-.03F5.
G41X.1Y.1422
X.13
G2X.1422Y.13R.0122
G1Y-.13
G2X.13Y-.1422R.0122
G1X-.13
G1Y.13
G2X-.13Y.1422R.0122
G1X.15
G40Y.21
G90G0Z.1
X.4203Y0
G92X0Y0
X0Y.21
G1Z-.03F5.
G41X.1Y.1422
X.13
G2X.1422Y.13R.0122
G1Y-.13
G2X.13Y-.1422R.0122
G1X-.13
G1Y.13
G2X-.13Y.1422R.0122
G1X.15
G40Y.21
G90G0Z.1
X.4203Y0
G92X0Y0
X0Y.21
G1Z-.03F5.
G41X.1Y.1422
X.13
G2X.1422Y.13R.0122
G1Y-.13
G2X.13Y-.1422R.0122
G1X-.13
G1Y.13
G2X-.13Y.1422R.0122
G1X.15
G40Y.21
G90G0Z.1
