586,108 active members*
3,107 visitors online*
Results 1 to 7 of 7
    May 2015
    4
    Diffrent cuts depth
    Hi everyone. I try to cut clock shape on mdf. Clock has inside and outiside cut. I use same tool for both full depth cuts, but tool didnit cut all the way through material in the inside toolpath, but cuts throught all tha way outside toolpath, same cut depth is on both tool paths. please help and sorry for my bad english
    May 2009
    37
    Re: Diffrent cuts depth
    Material not flat?
    Sent from my iPad using Tapatalk
    May 2015
    4
    material is flat
    May 2009
    37
    How thick was the mdf? It may have buckled slightly, I have found this when cutting through thin material.
    May 2015
    4
    6mm thick
    Post your V Carve Pro file and the g-code.
    May 2015
    4
    here is gcode and picture
  1. Depth of Cuts
    By Mattyvdv in forum MetalWork Discussion
    Last Post: 08-01-2014, 03:00 PM
  2. Feeds and depth of roughing cuts:
    By ruawake in forum Tormach Personal CNC Mill
    Last Post: 04-08-2013, 08:16 PM
  3. Typical Depth of Cuts for steel
    By Palinvan in forum Taig Mills / Lathes
    Last Post: 08-04-2012, 01:11 AM
  4. 4th axis tool path depth cuts?
    By clivefx in forum Mastercam
    Last Post: 07-20-2011, 09:36 PM
  5. MCX depth cuts question
    By charper in forum Mastercam
    Last Post: 02-07-2007, 05:46 AM
