Originally Posted by
bevinp
At the risk of telling you something you already know, you can easily add a new tool within SC. Start SC, Create a new operation (in Machining) by selecting Roughing --> Hole machining (this operation will list most of the tool types but not all; more info below). Enter the Geometric Parameters of the new tool, then change the Tool number to a number you think is correct. Press Add at the bottom of the window. If the number is already in use the SC will ask permission of overwrite.
As you can see, you can order the tools numerically the same way.... it just takes a little time. Also, using the same method you can group the tools into Types and order them by size.
If you want to do this, then first decide which Types you want them grouped into. But here is minor problem. On the Geometric Parameters page, SC matches the tool Types it will display to the Operation selected. For example, for 2D contouring, it will list all the mill types but not the Spot drill if it is Typed as a drill, So Type it as Conical Mill. SC displays drills and mills for Hole machining, so it will always be displayed there. To see what Types are displayed for each Operation, Create that Operation--> Tool Parameters page, then on the left just above the line drawing of the profile is a pulldown list of Types.
Once you decide the Types, assign a number block (allow for future additions), then edit each tool, but don't forget to Add each time.
When you've done all that, I would save a renamed copy of the .csv file as a backup.
Yes a fiddle and yes SC lacks many little refinements we expect for a $1000 program, but I'm used to it now and SC7 satisfies my needs.
Bevin
