586,043 active members*
3,885 visitors online*
Results 1 to 8 of 8
    May 2015
    7
    Batch of turned stainless parts, 85 pieces from 0.5" rod
    This RFQ is for a batch of ten variants on a single part. The parts are to be made from precision ground 0.5" stainless steel rod.
    The quantity of each variant ranges from 5 to 10 as indicated in the drawing. Total number of pieces is 85.
    These parts are for resale, consistency and aesthetics are important. Please specify the equipment that you intend to use for production.
    Re-ordering of these components is expected at higher quantities.
    Please provide your best quote, no "re-quoting" will be accepted under any circumstances.
    Send quotes and questions to [email protected]
    Thanks for your time and interest,
    Jon
    May 2015
    7
    Re: Batch of turned stainless parts, 85 pieces from 0.5" rod
    The quotes that I received over the past week were much higher than I expected.
    I have revised my request to be more cost effective.
    - Quantities are doubled
    - Rod diameter tolerance has been increased to -.002"/+0.000"
    - Any 300 series SS is acceptable
    For those of you that took the time to submit a quote for my original RFQ I very much appreciate you doing so and apologize for asking for more of your time with these changes.
    As always, thanks for your time and interest,
    Jon
    Attached Thumbnails Attached Thumbnails PostUniversal_Rev1.pdf
    Mar 2009
    88
    I thought requoting was not acceptable under any circumstances?
    Aug 2004
    780
    Whats the range you are looking for ??
    May 2015
    7
    You're right, I probably should have started a new thread when I changed the tolerances, material and quantities.
    -Jon
    - - - Updated - - -
    Quote Originally Posted by hanermo View Post
    Range in what?
    Jun 2005
    1015
    the problem your running into is that you want .500 +0 -.002 on an 8" pc that will be tough to hold. best bet for this material is preground 303 or 304ss. that gets expensive quick. also your part quantities are small. 10 and 20 pcs of each doesn't allow a cnc to be setup and left running for any length of time so it requires operator input. also if your hand chucking these than you will need to reset up the stop every 10 to 20 pcs.
    May 2015
    7
    I understand, thanks for your input.
    -Jon
    May 2015
    7
    This RFQ has been filled.
    Thanks for your interest,
    Jon
  1. Replies: 2
    Last Post: 07-10-2015, 02:18 PM
  2. Replies: 0
    Last Post: 11-22-2014, 07:11 AM
  3. RFQ: (2) 1/2" 304L Stainless pieces, approx 5"x4" each piece
    By tsdfab in forum North America RFQ's
    Last Post: 03-24-2013, 04:21 PM
  4. RFQ - More Turned Aluminum Pieces......
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 11-02-2009, 04:03 AM
  5. RFQ: Turned 304 stainless parts... 5/8" max diameter...
    By InspirationTool in forum Employment Opportunity
    Last Post: 06-22-2007, 09:43 PM
