586,080 active members*
3,485 visitors online*
Page 1 of 5 123
Results 1 to 20 of 82
    Sep 2003
    1469
    My First CNC Machine, Mr. Chips
    After MUCH reading and study from so many builders and designs I have finally put the mechanical portions together. There are too many people to thank for all the advice and the design tidbits I have plagiarized to finally arrive at this point. And yes this is my first machine, plan to use it to build an aluminum framed design with a movable gantry. One other factor that came to bare is that, how do you say… I am cheap, frugal…. And I let the good parts I found dictate the machine size as far as the X and Z axis are concerned. I did fine two good Thomson twin bearings at the recycle yard but the shaft was bent, I think I can use them for the Y axis of the 2nd machine, if I can find shafts at a good price, they are the full round design rather than the supported type which I would have perfered.
    Because I have very limited skills in metal work, and my desire to make it as rigid as possible the gantry sides and cross piece are made using two layers of ¾” MDF. With the cross pieces mortised through the inner layer of MDF. Everything on the gantry was glued and screwed. It is HEAVY, but rigid.
    Like everyone I wanted a machine that had as small of a foot print as possible and the largest work space, sounds reasonable to me, and dozens of other builders. This machine started it’s long life (evidenced by numerous holes) as a movable gantry, this impossibility soon became apparent when I mounted the gantry on the ¾” gas pipe rails (GPR) and supported by a four way adjustable bearing drilled and cut from a cutting board. This forced me to change the design to a movable table. This is not a bad choice as far as the function of the machine is concerned. The heaviest thing I will be moving around on the table will be a plate of aluminum big enough to make a side piece of the gantry for CNC #2. Yea I know famous last words.
    The base of the machine is made from one layer of ¾” MDF. The table I was building it on wasn’t very level so I used three pieces of 2” square steel tubing as a flat building plane. The end pieces are two layers of ¾” MDF, the inner one being stacked drilled at one time to insure the rails were parallel. Because the rails are so long I placed a piece of MDF under them in the center, and will place other pieces on the sides of the rails to reduce spreading. I was surprised at how little pressure it takes to flex this pipe. The pieces of wood on each side of the gantry running the full length were oriented with the annular rings running up and down this is a much more rigid orientation. I will add another one on each side for additional rigidity. The gantry is screwed to the base and has pieces of MDF on each side to further insure rigidity. Yea I know I’m obsessed with this rigidity thing.
    Thank you all again for freely sharing your ideas and time in getting me this far. Be forewarned as soon as I am making chips I will be calling on you all for advise with the software and how they interact/interface with the machine. Currently I am planning on using TurboCNC.
    Specifications/Parts:
    Over all size: 36” X 66”
    Usable table cutting area: 22” X 28”
    Z Travel 5½”
    X Axis rails 1” shaft with Thomson like bearings. Used …………………………….. $10
    Z Axis rails ¾” shaft with Thomson like bearings. Used …………………………… $10
    Not used on this machine 1” Thomson Twin bearings. Used …………...…………..…. $2
    Y Axis rails (gas pipe) ¾” ID (1” OD) …………………………………………� �.… $17
    Y Axis roller skate bearings 608 ZZ C3 Ebay from a Irvine CA distributor …….….. $16
    Controllers (3) XS-3525/8S-1 from Xylotex …………………………………………$1 20
    Stepper Motors 116 oz/in from Xylotex …………………………………………� �... $60
    Aluminum plate from Austin recycle center 0.68 per lb
    Drive screws ½” 10 Cannot lay my hands on receipt ………………..………Aprox. $45
    Here is an overall photo. Please see 2nd posting for questions I have about the alignment.
    Sep 2003
    1469
    Below are the readings that were measured on the table right after assemble. Measurements were taken from a grid that was 20” X 24” as shown on the drawing. From these readings I plan to place three steel cross braces under the table and bring up the center -0.038” and the two -0.015” readings and shim the -0.021” to be closer to Zero, then route the entire surface flat.
    Is this reasonable?
    Hager
    Jan 2004
    490
    Looks great. can't wait to see what it can do!
    Stop talking about it and do it already!!!!!
    2139
    Looks great! Sounds reasonable. For 2D cutting it's ok to be out a little. I would be mopre concerned about the perpendicularity (word?) of the y versus the x axis.
    Eric
    I wish it wouldn't crash.
    Aug 2003
    114
    Looking really really great! Very clean built.
    Greetings,
    John
    Sep 2003
    1469
    Eric,
    Checked the perpendicularity (word?) this afternoon by mounting a pen to the router post and locking the table and moving the router mount across the table drawing one leg of the triangle.
    Then locked the router mount on the X asis and moved the table, drawing the 2nd leg of the triangle.
    Used a starrett metric steel ruler.
    Marked X leg at 400mm, the Y leg at 500mm.
    Measured the third leg and it was 640mm long.
    This works out to an angle of 89.94 should have been 90.0.
    This is pretty close. I saw a CNC software where it allowed you to plug in this information and it would compensate the angle error when cutting.
    Does CNCTurbo have this feature?
    Hager
    Apr 2003
    470
    Work it out physically (shims and adjustments)... You'll be glad you did later.
    Nathan
    2139
    No, Tcnc doesn't do that for you.
    Eric
    Sep 2003
    1469
    Nathan,
    I figure I got lucky with an angle of 89.94 deg.
    Do you really think it is worth it to try and correct that 0.06 deg error?
    Would have to shift the X axis shafts less than 0.5mm on one end.
    Meaby I have to do this.
    Would like some comments.
    Hager
    2139
    What are you making? It's up to you. Can you live with it?
    Don't be discouraged. Get it finished and moving. you can twaek it any time.
    Eric
    Apr 2003
    53
    Hi Hager, Really nice job.
    Yes it is worth the trouble.
    Anything you cut later that has to work with anything else you cut will double the apparent problem.
    Even the softwares that compensate for this usually don't do you any good if you simply want to take the proven tool path and mirror it for an opposite component. there will be several more instances this will come of value.
    If you proceed with further assembly this is an easy ( at least geometrically ) correction. Cutting/ drawing a square or rectangle as large as you can, simply measure the diagonals and correct. Sorry if I am stating the obvious on the geometry.
    again, Nice job,
    Phill Pittman
    www.masterwerkes.com
    [email protected]
    Phill Pittman
    [email protected]
    Nov 2003
    314
    Looking good, can't wait till I am running a dial indicator on mine !!
    Sep 2003
    1469
    Thanks for the encouragement. When I get this tuned up and running I plan to make my aluminum CNC. So for it to be square and accurate this one will have to be.
    Working on the Z axis today, metal work is a new hobby for me, but I’m learning slowly and now have a lot of respect for you skilful machinists that produce those beautiful all metal machines.
    Picked up some plate at the recycle yard today. Keep my parts list with me because you have to pick it up when it’s available.
    Thanks again.
    Hager
    Sep 2003
    1469
    Lead Ssrew End Play
    Was working in the Z axis today and have a question about end play of the bearings on each end of the lead screws. This would apply to all axis.
    The lead screws are fairly long and during operation they will heat up and expand. Rather than setting the bearings up without any shaft end play, I’m thinking to not have any end play in the bearing at the stepper end of the shaft and 0.020” – 0.030” on the opposite end so it can expand freely.
    Is this the correct thing to do? Or is this too anal?
    Sorry didn't show the shoulder on the lead screw.
    Hager
    Put a nut on each side of the bearing at the motor end, to hold the position of the screw relative to the motor. Leave the other end free to float in the bearing. Or, if your machine is rigid enough, keep the screw under enough tension so it will always be tight. This is the better method, but more difficult to implement.
    Jan 2004
    490
    Is this one of the lead screw and stepper auctions from Manufacturist on Ebay? If so, they origionally had not bearing at either end, and they were mounted in medical industry equipment so I imagine that they are pretty solid as far as backlash goes. A friend and I powered up these med-rigs before they were dissasembled and they seemed pretty solid to me.
    Sep 2003
    1469
    Corrected Bearing/Retainer orientation
    You are correct, two or more heads are always better than one.
    If I flip the motor side bearing retainer over it will trap the bearing against the frame and retainer.
    The lead screw will be trapped by the nut and shoulder of the lead screw.
    Hobbiest,
    No, baught it all seperate and turned the shaft down.
    New Drawing.
    2139
    I used a bearing only on the no-motor end, and had the coupling on the motor end suport the screw. I did this on both my machines so far.
    Eric
    Sep 2003
    1469
    Eric,
    Did you use a rubber hose coupling ir metal? I was planning a fiber reinforced hose.
    2139
    On my first machine I used helical couplings. I was worried about the torque on the second machine so I made solid couplings, which I very quickly changed to short length of 3/8" ID hydraulic hose, with compression hose clamps (two ear clamps).http://www.thomasregister.com/olc/47884002/twoearcl.htm
    No slippage so far.
    Eric
Page 1 of 5 123
  1. Heads Up - Article about building CNC Milling Machine
    By samualt in forum Community Club House
    Last Post: 06-13-2005, 08:43 PM
  2. My CNC Machine and Questions
    By Davedbq in forum CNC Machine Related Electronics
    Last Post: 01-22-2005, 04:14 PM
  3. Interested in NY/NJ CNC machine demo...
    By jasonsp6 in forum Uncategorised MetalWorking Machines
    Last Post: 07-23-2004, 06:47 AM
  4. World's Cheapest CNC machine @ $100??
    By SuperCharg in forum DIY CNC Router Table Machines
    Last Post: 09-15-2003, 01:39 PM
