586,648 active members*
2,367 visitors online*
    Nov 2014
    14
    DX 32 back up software
    Hello everyone. Local community college closed it's machine shop course and I was able to buy a near mint Torq cut 22, for very little. Z axis board was blown but found replacement on E-bay for 500. The machine is now operational. I received the service and programming manuals but no back up soft ware. My concern is that it is a 19 year old computer and hard drive. Is there anyone who has the program that I could get a copy of for "just in case". Also , what would be the best/ easiest cad/ cam program I could use that won't break the bank. My understanding is that the DX 32 g-code is a little bit different than normal modern g-code. Any direction, help would be greatly appreciated. Thanks to all in advance. I reposted this because I think I might have used the wrong prefix the first time.
    Apr 2013
    40
    Re: DX 32 back up software
    Good morning,
    I dont have any of the software, but I just spoke with the OEM and we can still get software for it. Let me know if you are interested.
    Jon
    H&W Machine Repair
    Nov 2004
    164
    If the machine is operational, you should be able to back-up to a floppy yourself. I think there is a batch file called MAKEDISK.BAT on the machine you can run which, reportedly in the echo lines, backs up the necessary files for disaster recovery. There may be a way to execute this from the DX32 software, I just couldn't find it in the Maintenance Page on a precursory look so did it from the DOS prompt. I recommend you make images of that back-up floppy as well so you are not relying on the reliability/longevity floppies and drives. You could find DOS utility to back the entire C: drive image.
    Likely, the computer inside the TC22 has the typical PCI solid state DOM (disk on module) with no moving parts. I replaced the floppy with a USB emulator (SFR1M44-U100K ~$25 bucks on Ebay) which is much more convenient..
  1. laser cutting aluminum and stainless back to back
    By foreverdriven in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-11-2015, 05:36 AM
  2. think back to V18
    By MailleMas in forum BobCad-Cam
    Last Post: 12-17-2008, 06:21 AM
  3. Acramatic 850SX software back up - NEED HELP
    By bodopisti in forum Cincinnati CNC
    Last Post: 09-29-2008, 11:25 AM
  4. Back plot software
    By chrisryn in forum Parametric Programing
    Last Post: 06-06-2008, 12:22 PM
