586,113 active members*
3,089 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Post processing error
Results 1 to 7 of 7
    Jan 2012
    29
    Does anyone know what this error message means. It pops up when I try to post process a part I am trying to make. It will process the part and give me the code but I'm a little nervous to run it on the machine without knowing what this error code means. I have been over my tool library and can't find anything wrong. Machine is a Tormach 1100 series 3.
    SteveAttachment 279920
    Jun 2014
    1780
    Re: Post processing error
    Make sure you have the correct postprocessor file selected, seems like I remember that error when I first started using sprut 7, something to check.
    mike sr
    Sep 2007
    36
    This is a known error message. It does not effect your code. Email/call Tormach and they will fix it for you.
    Jan 2012
    29
    Quote Originally Posted by danh818 View Post
    Thanks for the quick reply. I'll give tormach a call and see if they can fix it.
    Steve
    Sent from my iPad using Tapatalk
    Dec 2008
    740
    You just need to download the latest post for Sprut9 from the Tormach site.
    Step
    Edit: from the title-bar it looks like you may not be using a Tormach post - is that correct?
    Jan 2012
    29
    Quote Originally Posted by TurboStep View Post
    Step
    Thanks, I'll download the latest post like you suggest. My sprutcam it the tormach only version. The post is the pcnc post but since I just upgraded to sprutcam 9 I probably don't have the latest version of the tormach post.
    Steve
    Jan 2012
    29
    Step
    Thanks Turbo, that worked great. No more error code.
    Steve
  1. Help! Error While Processing Block 0
    By fresko11 in forum Fadal
    Last Post: 12-05-2013, 08:11 AM
  2. Post Processing
    By machineitright in forum Dolphin CAD/CAM
    Last Post: 02-06-2012, 11:56 PM
  3. post processing for milltronics ?
    By ihbuilder in forum Visual Mill
    Last Post: 09-16-2011, 11:43 AM
  4. ISO post processing
    By imbalanced_MJR in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-23-2011, 08:05 AM
  5. Post processing.....
    By MrWild in forum Dolphin CAD/CAM
    Last Post: 03-22-2008, 07:43 AM
