586,060 active members*
4,191 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Best Method for Cutting 3/8 galvanized rod
    Mar 2015
    Looking for the best method to cut 3/8inch 1018 galvanized rod into 17.67" and 14.5" pieces with a tolerance of +/- .03". No chamfer or burrs on the ends. We would need to cut 4,000 pieces of the shorter rod and 600 of the longer rod per week. I was thinking of using a metal cutting bandsaw with the rods bundled together, but I am not sure if it is possible to hold that tight of a tolerance. Looking for ideas for speed and accuracy. Thanks.
    Jan 2007
    1795
    Re: Best Method for Cutting 3/8 galvanized rod
    henry
    there are a type of chopsaw..
    similar than used for trimwork..
    but this spin slow and of course mor e powerful.. I believe 7 can be cut at time..
    mightbe more, pending on the rod..
    of course need some type of jaw custom made..
    I think can be cut 1000 per shift at least.. with more clamped at time, more can be done...... and within tolerance..
    I post here a link, I cant tell this would be the best... it just illustrate how the machine looks..
    the length tolerance pending on the stop made.. make sure the worker can not bump out of position..
    stop need to be some how ""flip"" after positioning so material don't struck between stop and blade..
    Hyd-Mech P225 Cold Saw, Manual Coldsaw
    Feb 2009
    6028
    A good auto band saw could hold that tolerance no problem. We used to sell Daito band saws where I used to work, they would do it no problem, good quality saw, but around 20k back in the 90s.
  1. Best MDF cutting method
    By Karthik_ak in forum Community Club House
    Last Post: 07-10-2013, 04:39 PM
  2. Replies: 4
    Last Post: 07-03-2013, 04:08 PM
  3. What cutting method for this design
    By stevec1234 in forum WoodWorking Topics
    Last Post: 04-13-2010, 09:38 AM
  4. Best method for cutting down delrin?
    By chakup in forum Glass, Plastic and Stone
    Last Post: 10-01-2007, 12:53 AM
  5. Cutting galvanized
    By Scratch in forum Waterjet General Topics
    Last Post: 01-22-2007, 02:02 AM
