Originally Posted by
danh818
Yes, I am using a P9818 to correct for an A axis located along X, so my probe travels in Y.
You need to do something with the values that your P9817 macro records. Hence in my example: #5224=#189 (recorded value from P9818 macro is set to variable #5224 which is the G54 A value.) You can find a list of variables in the machine manual, or look up the pdf online, for me its on page 127 & 128. You should also look at page 36 of the Inspection Plus pdf.
Hope this helps.
Dan
