Goodday Guys
We have a Victor Mill
S/N: NK-1217
Year: 1986
System: 10M-A
South Africa
We recently had a memory corruption and our technician reloaded the control using the IPL menu and hard copy ( Printed Sheet ) of option parameters , data , keeprelays , counters , timers and parameters.
We however are having problems running programs , the program just stops after 3 lines , there are no alarms.
We are missing the macro programs and think that this may be a issue.
We are not using the tool changer so we don’t think that the macro for tool change is the issue , are there any other macro programs that are needed?
Here is the start of the program. The spindle starts up fine and the Z axis moves to its start position and then just waits.
O0002 G28 G91 Z0.0
G28 X0.0 Y0.0
G0 G90 G54 X15.0 Y65.2 S2000 M3
G43 Z100.0 H01 M8 ( The Program Stops Here Before The Z Axis Moves The 5mm )
Z5.0
Z2.0
G1 Z-0.3 F1000.0
We hope that you can assist.
We also don’t know how accurate the parameters are from the printed sheet. We have a backup of the control parameters from when the machine was running.
But not the Options or Data (eg. Timers Counters ) these are only from the printed pages.
Thank You In Advance
