586,060 active members*
4,258 visitors online*
    Jul 2007
    7
    Victor 4 Fanuc 10M
    Goodday Guys
    We have a Victor Mill
    S/N: NK-1217
    Year: 1986
    System: 10M-A
    South Africa
    We recently had a memory corruption and our technician reloaded the control using the IPL menu and hard copy ( Printed Sheet ) of option parameters , data , keeprelays , counters , timers and parameters.
    We however are having problems running programs , the program just stops after 3 lines , there are no alarms.
    We are missing the macro programs and think that this may be a issue.
    We are not using the tool changer so we don’t think that the macro for tool change is the issue , are there any other macro programs that are needed?
    Here is the start of the program. The spindle starts up fine and the Z axis moves to its start position and then just waits.
    O0002 G28 G91 Z0.0
    G28 X0.0 Y0.0
    G0 G90 G54 X15.0 Y65.2 S2000 M3
    G43 Z100.0 H01 M8 ( The Program Stops Here Before The Z Axis Moves The 5mm )
    Z5.0
    Z2.0
    G1 Z-0.3 F1000.0
    We hope that you can assist.
    We also don’t know how accurate the parameters are from the printed sheet. We have a backup of the control parameters from when the machine was running.
    But not the Options or Data (eg. Timers Counters ) these are only from the printed pages.
    Thank You In Advance
    Aug 2007
    793
    Re: Victor 4 Fanuc 10M
    may be inposition range of Z axis too low
    the machine stops after any block with Z axis moving?
  1. Victor V center-4 Fanuc 10M Help!
    By vladimir1409 in forum Fanuc
    Last Post: 02-10-2016, 12:27 PM
  2. Victor 4 Fanuc 10M
    By vleisman in forum Fanuc
    Last Post: 05-13-2015, 08:09 AM
  3. fanuc 10m on a victor v center 4
    By skippyfix in forum Fanuc
    Last Post: 12-03-2012, 08:53 AM
  4. Fanuc 10T on Victor lathe
    By Chais82 in forum MetalWork Discussion
    Last Post: 10-23-2012, 02:26 AM
  5. Victor VMC fanuc 10M
    By Dheimification in forum DNC Problems and Solutions
    Last Post: 11-14-2011, 09:35 AM
