586,043 active members*
3,906 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0iMC -9031 Motor lock or V Sig Loss
Results 1 to 6 of 6
    Dec 2006
    310
    Dear Sirs
    In MDI/Auto mode, only in case of one particular tool, when spindle speed is more than 1500 rpm, we find Load on spindle (L) as seen at the bottom of position screen to be shooting upto 164%(although tool is running on load ie not in touch with job) and hence trips with alarm 9031, we dont have this problem in case of any other tools even at 2000 rpm
    We replaced tool with new one
    Spindle Motor has timing belt and there is no gear box.
    We can not doubt feedback, as no problem in case of any other tools even bigger than this one
    With same set of toolings and same job being made since last 5 years
    Kindly revert
    Feb 2012
    Re: Fanuc 0iMC -9031 Motor lock or V Sig Loss
    9031 spn 1 motor lock alarm on fanuc control cnc mill
    Apr 2012
    85
    Does the motor have dual winding contactor? It may be one 'range' contacts are bad.
    Nov 2006
    175
    I would check the pullstud first, if it is different, it may lead to different travel of the collet mechanism
    Dec 2013
    39
    Quote Originally Posted by M.RISHIKESH View Post
    Dear Sirs
    Kindly revert
    TRY M 40
    M 41
    or check the motor
    Feb 2019
    7
    IS the tool too heavy? Try to lower the speed.
  1. Fanuc 0iMC PCMCIA CF Memorycard
    By anderin in forum Fanuc
    Last Post: 05-23-2022, 03:56 PM
  2. Serious problem in new Fanuc 0iMC.
    By motordude in forum Fanuc
    Last Post: 08-09-2021, 01:35 PM
  3. simulation in Fanuc 0imc
    By ahmed4040 in forum Fanuc
    Last Post: 05-30-2010, 09:37 AM
  4. Fanuc 0iMC param. problem.
    By GPena in forum Fanuc
    Last Post: 08-12-2009, 04:05 PM
  5. tool change prblem with fanuc 0imc
    Last Post: 01-06-2008, 10:17 AM
